Question about Samsung Jet S8000 Cell Phone
Samsung S8000 volume button problem
1. When I press the 'down' volume button it doesn't decrease the volume but instead brings up the call history. This is a used phone that I bought from ebay - is this the normal function of the down volume button and if not how do I change it back?!
Can I turn off my 55 inch Samsung tv without using my Comcast control? My Comcast control does not work.
Hope this helps.
What is Jog Controller in Samsung TV's ? Last Update date : 2016.11.11
The Jog Controlfeature is a quick and easy way to enable and access certain functions and features on yourSamsung TV without a remote control. Television now use a Jog control instead of touch buttons to control the TV without the remote control. This control is located on the rear or bottom right side of the TV and will feel like a little joystick. Move the Jog conroller towards the icons indicated on the all four sides to control channel and volume. Press and hold the Jog controller to turn off the TV.
Here are some description of Jog Controller :
Channel Up : Changes the channel upward.
Channel Down : Changes the channel downward.
Volume Up : Increases the volume level.
Volume Down : Decreases the volume level.
Display on the bottom right of the TV screen opens by pressing Jog Controller once :
Smart Hub : Opens up Smart Hub.
Return : Brings back to the TV viewing.
Source : Changes the source.
Power Off : Turns TV off.
Menu : Opens up the TV Menu.
Related Model Information PS43E400U1R, PS43E470A1R, PS43E490B3R, PS43F4100AR, PS43F4900AR, PS51E470A1R, PS51E490B3R, PS51E550D1R, PS51E8000GR, PS51F4900AR, PS51F5500AR, PS51F8500AR, PS64E8000GR, PS64F8500AR, UA22ES4003R, UA22ES5000R, UA22ES5005R, UA22ES5100R, UA22F5000AR, UA22F5100AR, UA23F4002AR, UA23F4003AR, UA26EH4000R, UA26EH4800R, UA28F4000AR, UA28F4100AR, UA32EH4000R, UA32EH4003R, UA32EH4500R, UA32EH4800R, UA32EH5000R, UA32EH5330R, UA32EH6030R, UA32ES5600R, UA32ES6200R, UA32F4000AR, UA32F4100AR, UA32F4500AR, UA32F4800AR, UA32F5100AR, UA32F5500AR, UA32F6100AR, UA32F6400AR, UA39EH5003R, UA40EH5000R, UA40EH5330R, UA40EH6030R, UA40ES5600R, UA40ES6200R, UA40ES6600R, UA40ES6800R, UA40F5000AR, UA40F5100AR, UA40F5500AR, UA40F6100AR, UA40F6400AR, UA40F6800AR, UA40F7500BR, UA46EH5000R, UA46EH6030R, UA46ES5600R, UA46ES6200R, UA46ES6600R, UA46ES6800R, UA46ES7500R, UA46ES8000R, UA46F5100AR, UA46F5500AR, UA46F6100AR, UA46F6400AR, UA46F6800AR, UA46F7500BR, UA46F8000AR, UA50F6800AR, UA55ES6200R, UA55ES6800R, UA55ES8000R, UA55F6400AR, UA55F7500BR, UA55F8000AR, UA55F9000AR, UA60ES8000R, UA60F6400AR, UA65ES8000R, UA65F8000AR, UA65F9000AR, UA75ES9000R, UA75F6400AR, UN26EH4000M
Jan 27, 2017 | Samsung Televison & Video
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
What is the problem when samsung S8000 is always ON and OFF?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 05, 2012 | Samsung Jet S8000 Cell Phone
I have samsung galaxy I. my phone was turned off and when i turn it on it doesn't start as it stucks on samsung and doesn't start up. i took off the battery off and on but it still not working
hi,
try to hard reset your phone first by doing this procedure...
To Hard Reset Samsung I9000 Galaxy S
1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
3. Press and release the Power button
4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
6. Press and release the Power button
7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If YES is selected, all data including third-party applications will be deleted from your Samsung I9000 Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
if you do the above procedure and nothings happen ,its time now to re-flash your phone to its original version and a certified mobile technician will do that for you...thanks for trusting fixya
Oct 01, 2012 | Samsung Galaxy S GTI9000 Smartphone
How to put on silent mode at when incoming call on samsung b7722
hi francis,
When u r getting incoming call, press volume decrease button on left side of the mobile, it gradually decreases ring volume....!
Long press on the same button will at once makes it silent!!!!
Try it!!!
Nov 20, 2011 | Samsung Cell Phones
How to reset my samsung galaxy
METHOD TO RESET GALAXY
STEP 1: Switch off your phone, remove its battery, and then place it back.
STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
STEP 3: Now you will get a list of options to choose from. Which would be like:
  • Fastbook
  • Recovery
  • Clear Storage
  • Simlock
STEP 4: There, choose the Clear Storage option.
NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have samsung g 19000 and i have forgot my unlock
hi,
if you forget your lock code try to reset your phone in ths easy way...but i want you to know that all of your data will be deleted...
here is the instruction...
reinsert it
and Simlock
If the above procedures doesn't work, use this second method below,
1. Shut Down Samsung I9000 Galaxy S
2. Now press the Volume up, Home and Power button together.
3. When Samsung Symbol shows up release the power.
4. Then there is a boot Menu. Use the volume up/down to choose and home to select.
fresh state.
Apr 14, 2011 | Cell Phones
How can I bring DOWN the volume (on my Eclipse CLD2 MP3) ?
press the volume buttom, then press the left button(the same button which you can go back to listen to previuos track <<| )..make sure that vol is highlighted on the screen of your clip in mp3. Once volume is higlighted just press right " |>> "button to increase volume or the " <<| " to decrease volume...
Jul 12, 2010 | Eclipse CLD2 MP3 Player
Samsung Jet S8000  Cell Phone Logo
330 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
