Question about Canon PowerShot SD1000 Digital Camera
Canon power shot sd1000 black dot on lens
The upper right corner of my lens has a black dot.
  • Canon Master
  • 3,289 Answers
If by saying the upper right corner of the lens you really mean that there is a dark spot on each image AND the rear display, there may be dirt or dust on the lens itself. Clean the lens with an optical quality cleaner. Do not use paper towels and Windex or the like - as paper towels can scratch the lens.
It is also possible that the dark spot is a "stuck pixel" on the image sensor inside the camera. There is no way to repair a stuck pixel outside of replacing the sensor. Any dark spot (regardless of source) can be edited out by using image editing software. This will allow you to to make the dark spot less noticeable - or practically invisible.
If the dark spot is on the rear display only, it can also be a result of a "stuck pixel" on the display itself. This should not show up an images, but only on the display. There is little that can be done outside of replacing the entire rear screen.
There are other things that can cause these problems, but those listed above are the most common.
I hope this was Very Helpful and good luck!
Posted on Nov 20, 2009
Ecently a small dull black dot has started appearing on my canon power shot A630's lcd screen but when I review the pics taken prior to when I noticed this problem, no dot appears.
1) this is indicative the lcd camera has been faulty.
2) you must replace it.
3) contact your company supplier, and get the parts, you can do it yourself, only need small screwdrivers and common sense.
God bless you
Sep 17, 2012 | Canon PowerShot A630 Digital Camera
My Canon PowerShot SD1000 won't focus. Most
Sounds like you may not be in "Auto" mode. Press the "Func/Set" button, then press Right or Left to select the "Auto" mode.
Nov 01, 2009 | Canon Powershot A1000IS 10MP Digital...
My Canon Powershot SD1000 has a fully charged battery but won't turn on at all.
Does your camera turn on when it's in playback mode? I have a similiar problem with mine. It only turns on in playback mode.
Sep 25, 2009 | Canon PowerShot SD1000 Digital Camera
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
Power shot, refuses to completely turn on, the screen is black expect for 'E18' in the bottom right corner, 4 beeps, then the system turns off. What is happening?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jun 25, 2009 | Canon PowerShot A95 Digital Camera
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
Canon SD1000 Power Shot Lens Error
try to reset the camera, take the battery out for a while..
let me know..
micro-
Sep 10, 2008 | Cameras
Canon SD1000 display is black while the camera in shot mode
After some inspecting of the camera it seen the issue lies with the lens, not the camera itself so don't go banging the camera up or you might damage some other part and the camera will be broken for real. Inside the lens is a closer which block the internal system from capturing image. The closer look just like the one you see before turning on your camera but it's smaller and it's inside the lens way in the far back. Look carefully and you'll see it - you will see the closer if your screen is black while in capture mode otherwise you will see a nice round glass (the internal lens for capturing image/video).
Think of if like this, imagine an eyeball with its eyelid close. That's what happened when the screen is black while in capturing mode.
HOW TO FIX IT: In order to fix the black screen while in capture mode and cost as little damage to your camera as possible, simply turn on the camera in either picture or video mode and look inside your lens, there should be a closer in the far back end. Gently hit the lens a few times until you don't see the closer no more and only a round glass and your camera should begins capturing image and video again.
Good luck to you all. And remember don't use anger to force your camera to works or you will regret it.
If you need further help, contact me via email y a j y e e (at) h o t m a i l (dot) com
Yee Yang
May 13, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
592 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
