Question about Kitchen Ranges
Replace lamp in simpson rdn6s rangehood - Kitchen Ranges
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
How do i replace the lightbult in the robinhood 2000 rangehood?
It depends on the model but Instructions can be found in the operating manual that came with your rangehood or as a PDF on the product pages of the website
http://www.Robin Hood.com.au
Jul 12, 2014 | Kitchen Ranges
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
I have a qasair rangehood (uv-1200-2) with 2 lights. The lights have not worked for a year or so. I have now replaced them (following http://www.qasair.com.au/images/installation_inst/QAIInstr_Lamp.pdf )...
First, turn off power to the rangehood. Check the contact resistance of the light switch(es) with an ohmmeter. It should be less than 0.1 Ohms. If you get a substantially higher resistance in the on position, the switch contact is burned out. Also, inspect the wiring harness connector and the connections to the light fixtures. If they show signs of overheating, the connection resistance is too high. You can try polishing the connector contacts to remove oxidation. I use a pencil eraser for mild cases and a non-metallic dry scouring pad (3M Scotch-Brite) for more severely tarnished contacts. In the worst case it will be necessary to replace the terminals or connector.
According to the drawing for this series on the Qasair website, the unit uses fluorescent lamps rather than the halogen lamps referred to in the lamp installation instructions. If this is true, it is likely the ballast has failed (if the lamps have separate switches, they probably have separate ballasts also). If the original ballast model is no longer available, make sure the replacement has at least as high a maximum temperature rating as the original. This is especially critical for electronic ballasts. You can extend the life of the new ballasts by making sure the fans are running before turning on the lights - this should reduce the ambient operating temperature inside the hood.
May 25, 2011 | Microwave Ovens
How to replace a bulb for kd rangehood
This is for a smeg KD series, it depens on the model which lights are used.
LIGHTS REPLACEMENT:
Before performing any cleaning and/or
maintenance operation, disconnect the hood
from the mains supply.
According to the model, the hood can be equipped
with different kind of lighting such as incandescent,
halogen and neon lamps.
a) Incandescent lamps: E14 – 40W 230V lamps.
To replace them, remove the transparent fixture
from the control panel, unscrew the lamp and
screw in the new one.
b) Halogen lamps: G4, 20W - 12V lamps . To
replace the lamp, use a screwdriver to remove
the glass-supporting ring. Then remove the old
lamp and insert the new one.
Put the glass back, securing it with the ring.
c) Biax neon lamps: G23 11W lamp. Once the
fixture has been removed, remove the biax lamp
from its seat and support.
Put a new lamp in, performing the same
operations backwards.
d) Neon lamp: 15/18W neon tube. To reach the
neon tube, unscrew the glass framework screws.
Rotate the tube 90 degrees and remove the neon
lamp. Install the new neon tube and put the glass
framework back.
Hope this helps
Apr 13, 2010 | Kitchen Ranges
Vulcan Dishlex Series 3 Rangehood
vulcan is a hobart compay. call them and they will send you some
Aug 20, 2009 | Vulcan 36" WIDE ELECTRIC(Click Here): WALL...
Electronic Control Not Working
The electronic controller is faulty. You will have to contact the supplier where you purchased the rangehood from to find out who the warranty agents are for that make & model.
Nov 03, 2007 | Venmar CONNAISSEUR 5000 Kitchen Hood
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
