Question about Nokia 6700 Classic Cell Phone
How can I set up a repeat alarm for a Nokia 6700 on incoming text messages, my previous Samsung phone would sound every 2 minutes which I found very useful?
How do I set my samsung S111 to repeat the notification of an incoming text until I answer it?
Click on "messging" like you're about to read a text, then click on left hand side and a few options should come up, click on the "settings", scroll down until you find the "notification settings", then click on "message alert repetition", you should be able to change it to either "once, every 2 minutes or every 10 minutes"... hope that helped
Sep 24, 2014 | Samsung Cell Phones
How do I set my samsung S111phone to repeat the notification of a text until I answer it?
Kindly follow the steps listed below to do so:
  1. Go to Apps through Home screen.
  2. Tap Messaging.
  3. Tap the Menu key.
  4. On pop up menu select Settings.
  5. Scroll to Notification settings section then tap Message alert repetition.
  6. Here you can see three options available on pop up menu. They are:
    • Once: Choose this option if you want your phone ring the tone just once when receiving an incoming messages.
    • Every 2 minutes: Choose this option if you want your phone ring the tone every 2 minutes until you open the message.
    • every 10 minutes: Choose this option if you want your phone ring the tone every 10 minutes until you open the message.
  7. Tap the required message alert repetition option you wish to use. When the dot indicator next to the option shows green means the option is selected.
  8. Tap Home button to return to the standby mode.
By adjusting message alert repetition just once or more than once, now your phone will notify you when receiving new message and repeating the tone according to the settings you've just done. So, what's the option you use on your phone?
My nokia 6700 won't show up new text messages. I have to go into the Inbox to see if there is a new message. It also won't make any sound either even though it is set and not on silent
just restore default setting go to setting phone setting and restore original setting. make sure you save numbers to sim and files to memory card.
Sep 18, 2011 | Nokia 6700 Slide Cell Phone
Just got a nokia 6700 and when i try and send a text message it fails
hi...
please check the message centre number.this number might have accidently changed .Call your service provider and ask for the message centre number.
To set the number please folow these steps...
Menu---->Messages---->message setings---->text message----->message centre number
In that you can set the message centre number which was given by your service provider.
thanx
Jul 27, 2010 | Nokia 6700 Classic Cell Phone
My Samsung Reclaim Samsung cell phone doesn't send/receive texts sometimes and I don't get calls, what is the fix?
My phone makes a weird noise when I don't get a text. I don't know where they go but, for some reason it sounds an alarm when texts are not recv'd. It took me awhile to realize that it was notifying me that an incoming text was not recv'd. I am not sure why this is a feature because, it does not notify you whose message did not get sent to your phone
Apr 06, 2010 | Samsung Reclaim Cell Phone
How can I set repeat incoming text alert tone till text is read.
this should be in sound setting its absending you want set it on
Aug 14, 2009 | Cell Phones
Ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
May 21, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Apr 28, 2008 | Samsung SGH-E900 Cellular Phone
Motorola E815 alarm quit working
I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
Oct 08, 2007 | Motorola Mobility E815
Nokia 6700 Classic Cell Phone Logo
204 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
