Question about LG WM2277H Front Load Washer
LG code for motor overload-- I am in the repair service and need more instructions on a LG wm2277H
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 161 Answers
Unplug remove the back. Loosen large bolt in center of rotor. Slide rotor off of spline. Look at the stator with the windings. At the bottom of the stator where the harness plugs in is the hall sensor. Remove the 10 mm bolts holding the stator on and don't let it drop. Un plug the plug and snap the hall sensor off and snap the new one on. Re assemble.
Posted on Jan 28, 2010
Manual for wm2277h washer
Either from manufacturer or from an online supplier on a prepay basis. Do a Google search to find out where to obtain it.
You will need to specify whether you want a USER (Instruction) manual or a SERVICE (technical) manual for your machine.
Poppa
http://www.cdbaby.com/cd/poppamadison
Apr 03, 2012 | LG WM2277H Front Load Washer
I have an lg wm2277h washing machine, i keep getting LE error at display how can i fix this?
This is caused by a bad Hall Sensor. when it is bad it tells the computer that there is too much load on the motor, therefore giving you the LE code, otherwise known as a (Locked Rotor Error). It is cheap and fairly easy to replace, the part can be ordered at Sears Parts, using your model number. For information on how to perform your repair, please reply.
Thanks, Repairman45
Dec 20, 2010 | LG WM2277H Front Load Washer
Le error code what is this
this code means a Locked Motor Error. you need to check the hall sensor it may be defective and you may also have to replace the Stator Assembly. this will require an appliance service call by a qualified LG technician.
Nov 07, 2009 | LG WM2277H Front Load Washer
5 year old LG WD-1219BD has error code LE, ''overload in motor''
LE is a very bad error unfortunately. It means that your motor communication is being lost. Generally on these LG washers it means that you need to replace the motor sensor. You will have to take the back panel off so that you can access the motor, remove the pulley and take the motor off, there is a little plastic sensor that clips onto the edge of the motor. The sensor is not sold separately from the motor so you will have to replace the motor unfortunately.
Part would cost you around $120 plus labor.
This is a common error on LG. Better to repair and use it or fix it yourself.
Hope i helped you,
Thanks for using ' Fixya ' and have a nice day!!
Oct 11, 2009 | LG WD-1295FB Front Load Washer
Error code LE on front load LG washer
This is a motor fault code. Sometimes it can be just a communication error, in which case you can try unplugging the machine for 20 minutes and see if it clears the problem up. More likely it is a fault in the motor itself. The most likely culprit would be a defective hall sensor. I will attach a photo of the sensor for you to see what it looks like. To access and replace the hall sensor, you have to remove the rotor and stator at the motor. Before going to this trouble, try the unplugging thing first and also check the connector on the main control board. It is the red connector next to the heat sink2.gif. Using a multimeter, check that the board is receiving a signal from the sensor. Hope this helps and best wishes.
Sep 02, 2009 | LG WM2277H Front Load Washer
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
My lg wm2277h washing machine has a le error code. and where i can find the water circulation nozzle
This is the motor overload code. Most often it is caused by too much detergent. Really if you use more than a couple of tablespoons, you risk setting off this code. Anyway try unplugging the machine for five or ten minutes, then plug it back in . It should work. The techs have a series of button pushes that do the same thing followed by a too much soap lecture.
Nov 25, 2008 | LG WM-2277HW Front Load Washer
LGWM2277H LE light came on does the motor have a reset button i need to push
Hello momof3611
Welcome,
You said, Your LGWM2277H washer LE light flashes. Troubleshooting guide says overload in motor. Is there a reset on the motor that needs reset or does something else need done. washer was working fine until we put a big load of jeans in to wash. when we checked wash soapy water was in washer and I can't get it to rinse. drum is not turning.
If you overload, with to much clothes the weight will trigger this error your having in most washer.
Take some clothes out.
Then try this:
Unplug the washer for 5 minutes, or if you can't reach the plug, turn the breaker off for 5 minutes and then the system should reset itself!
Let me know.I'm looking right now for any reset code in the repair manual too!
Huuum
Please remember to leave a rating.
Oct 07, 2008 | LG WM2277H Front Load Washer
Lg washer
From the manual - LE is overload in motor. Restart the cycle after 30 minutes. If LE is not released, call for service.
Jun 04, 2008 | LG WM2277H Stainless Steel Front Load...
LG WM2277H Front Load Washer Logo
230 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
