Question about Bosch Axxis+ WFR 2460 Front Load Washer
Spin speeds spin speed 600 or 1200 how do I select
  • Barry Coates
    Barry Coates May 11, 2010
    There should be a button on the control panel showing 600 or 1200 just press it to select the appropiate spin speed.
    Please rate my solution.
    Thanks.
  • Bosch Master
  • 3,463 Answers
I thought I had replied to this post before, however, you should have a button on the control panel showing 600 or 1200.
Just press the button for the correct spin speed.
Thanks.
Posted on Nov 21, 2009
My washer is stuck in fast speed. Can't make it agitate in slow speed. Model # 110 26892690 .
I assume you mean spin.You should have a slow/half spin selection on your machine if not select a delicates or wool program this will give you a slow spin.
Feb 24, 2015 | Washing Machines
How do I get my machine to just spin a load? It became unbalanced and I adjusted it and now just want to spin the water out?
Turn power on. Without selecting a cycle, push the spin speed button to select the spin speed you desire. (if you had an unbalanced load, I'd suggest a low spin speed. You can repeat after with the next higher speed if desired) Push start.
This will give about a 12 to 14 minute pump and spin only cycle.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
LG Washing Machine Model : WD658 When using the function "Rinse & Spin", the timer decreases when rinsing. However, the timer decreases and stops at 9 minutes. This results the machine...
Try setting a lower spin speed. You may have a bulky load which the washer is having a difficult time getting up to the high speed spin you have selected. Also, did you know that on most LG washers, you can do just a spin without a rinse? Just turn the washer power on, then, without selecting a cycle, just push the spin speed selector to select the spin speed desired. This should set the cycle for about a 12 to 14 minutes pump and spin only. Then push start. You can spin that bulky load at the lowest spin, then try it again at the next faster spin if needed, without adding rinse water.
Mar 15, 2011 | Washing Machines
Screen reads UE? what is UE?
UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
Apr 11, 2010 | LG WM-2277HW Front Load Washer
Will only spin slow speed will not spin at high speed. Everything else seems to be working fine.
Make certain that your selected wash cycle designates a higher spin speed. If so, then you may have an issue with the motor or motor control board. Contact an appliance service company.
Feb 22, 2010 | EuroTech EWF172 Front Load Washer
Wont finish a small load. Gets to 4 minutes and
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Nov 17, 2009 | LG WM0642H Front Load
Will not go into high speed final spin after rince cycle..only spins back and forth slowly and the uE indicator comes on stopping the machine. Have tried taking out a few laundry items and re-starting and...
uE is unbalanced error. When you have bulky items, wash them with a slow spin speed. Larger loads actually balance out better, so adding items might help instead of subtracting them. After the cycle completes, if you want to you can turn the power on again and (without selecting a cycle) just push the spin speed selector button and select the next highest spin speed. The load will most likely make it through the next higher speed now that it is partially spun out. You should get a 14 minute spin and pump only when you start it now.
Nov 15, 2009 | LG WM0642H Front Load
Spin cycle works sometimes, or does not spin hard enough to remove most of water
Many high-end washers have two spin cycle speeds. The low speed is for delicate fabrics. Yours may be stuck in the low speed. Check that you are selecting the wash cycle with the high speed spin.
If you are and it continues to spin at the low speed then your controller is most likely at fault. Your gearbox could be bad too but it usually complains with a lot of noise.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Slow spin
open the unit. check all motor windings for continuity. motor may have more than one winding for multiple speed
May 13, 2007 | Whirlpool GHW9150 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
107 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
