Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
No image at menu 'digital'
I connected digital decoder (Humax)to the AV entrance (scart cable). I only receive digital tv on the menu at AV1. I don't receive digital programs when I press "digital" (it shows no image)
The analog programs function fine. I programed both the digital as the analog channels, but I can only view the digital chanels if I go to AV1. How can I view the chanels using the menu digital? It shows the chanels and guide, but no image.
  • 834 Answers
You connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Posted on Nov 20, 2009
How do I get sky tv through my philips mx5100vr home theatre
External Input Mode (for VCR features) To receive the signal from an external input (decoder, satellite receiver, video camera, another VCR etc.), connect to the AV2 (DECODER) socket, and enter "002" with numerical key pads to appear "AV2" on the TV screen.If you use the AV1 (TV) socket, enter "001" with numerical key pads to appear "AV1" on the TV screen. If you use the front AUDIO/VIDEO input jacks, enter "003" with numerical key pads to appear "AV3" on the TV screen.
Apr 25, 2015 | Philips MX5100VR System
Autosetup on my DVB is not picking up stations. The TV is connected directly to the satellite dish and has all free sat stations. As far as I can see all the connections between the TV and DVB are as
I'm wondering where in the mix is your satellite receiver? The recorders currently on the market aren't able to decode digital satellite signals. They are capable of decoding cable but i'm unaware of any that work on satellite.
Sep 17, 2014 | Panasonic Televison & Video
My youview has taken over my humax channels
Put BT box into standby. This is probably due to the scart connection. Try to connect both boxes via HDMI if possible.
Aug 23, 2014 | Humax Televison & Video
I can't get the tv to program the cable connection to watch cable
use a scart lead to connect your cable tv box. then on your tv remote press the "source" button or press the "AV" button, you mainly have the options to choose AV1 and AV2 (AV2 is only available if your tv has 2 scart sockets) make sure the box is on and select any AV channel, you should now have cable tv.
Jul 17, 2012 | Disney Princess TV/DVD Combo
Hello, I have this older surround set, the Yamaha AV1. I gave it to my yonger nephew, hoping he could use it with his LG flatscreen television and playstation 3. I don't know how i can get the...
All sound should go directly from its origin to the sound systm. All video should go directly from the source to the TV if it has enough inputs. NO signal ever benefits from unnecessary routing and cabling to or through a device that neither uses nor improves it.
Hint: TV's don't improve the sound or even need it if you have a hi-fi..
Aug 16, 2011 | Yamaha AV-1 System
I have a Panasonic Tx l37S10B tv set, & a PanasonicDVD recorder,DMR-EX768EB. To ensure I receive true HD i have bought a Humax Fox T2 hd Digital receiver. I use these items to receive & record HD...
You didn't fully expain how each device is connected to the others. I don't think you have this set up correctly. Your DVD cannot record in HD so there is no point sending an HD signal to it - it can't process it. This is how I would set it up:
1. Install a 2-way splitter on the input cable
2. Connect output 1 from the splitter to the Humax receiver
3. Connect the Humax receiver to the TV with an HDMI cable
4. Connect output 2 from the splitter to the DVD
5. Connect the DVD to the TV with SCART cable.
This will enable you to watch HDTV via the digital receiver and also provide an input from source (dish/cable) to your DVD player so that you can record.
If you've already set it up this way then it should work. I suspect you've connected the Humax to the DVD and TV and also the DVD to the TV.
Please try this setup and post back if you need further assistance.
Nov 04, 2010 | Panasonic Televison & Video
I have bought a Humax digital recorder and
What model is it? The Humax Terrestrial PVRs have two SCART outlets. If by chance you have connected the TV to the VCR SCART socket rather than the TV SCART socket then you will get the symptoms you describe. Plug the SCART into the other socket.
Dec 23, 2009 | Televison & Video
When trying to switch from AV1 to AV2 with the
The Red, White & Yellow connectors are your composite inputs usually classed as AV3 or component. The AV1 input is a Scart connection, if you have a scart cable, connect this as your AV source & the TV will switch from AV to component.
Oct 24, 2009 | LG Televison & Video
How do u turn to scart channel without a remote
Not knowing what model of TV you have, the most common ways are either by using the Source button then scroll to AV1 input or if you have a Menu button there may be a sub-menu for Input, again select AV1 (depending on which AV connector you are linked you maight have to select AV2). If you have a DVD or VCR connected to the AV source, then when pressing play the DVD/Tape should automatically switch over to AV.
Jul 08, 2009 | Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
178 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
