Question about LG Shine KE970 Cellular Phone
Screen cracked need to transfer contacts to sim ?
Screen cracked down the middle on LG shine, need to transfer contacts to sim, what sequence of buttons do i press?.
How do i save all my info to my sim card? my screen is cracked so i can't see what i'm doing.
You can copy all your contacts in the sim card by going to contacts -> settings -> and copy all the contacts to your sim. Other information or data can be copied to memory card only.
Jul 24, 2010 | LG Shine CU720 Cellular Phone
Broke screen on a lg shine model cu720 how do i transfer contacts to simcard
HI...
unless and untill you replace your displace you will not be able to trnsfer the contacts to sim.
If you have same mobile with you can check and do by press keys according to this mobile in your broken screen mobile...but you can do by trail and error method only and it may be risky too. but you cannot be sure that you have coped all the contacts to sim
thanx
Jul 18, 2010 | LG Shine CU720 Cellular Phone
Our screen has cracked and we cannot read it, we need to transfer the contacts from the phone to the sim. Can you please help?
You need to install the software (pc suite) that comes in the CD the first time you bought your LG shine . If you don't have the CD , then you can download the software (pc suite) from www.lge.com . By this software you can back up all of your phone's data including the contacts .
good luck .
Jan 25, 2010 | LG Shine KE970 Cellular Phone
Broken screen
try menu (left soft key) > down three, right one > press 5 > press 2 > press 1.
That should do it.
Oct 02, 2009 | LG Shine CU720 Cellular Phone
Using the usb cord to get pictures off LG shine on to my PC
i found this on another website, i was having the same problem with my lg shine slider....but ne way this worked for me maybe it will work 4 u.....
Make yourself a new contact (I used "me"). Scroll down and add your e-mail address and NOTHING else.
Go to Menu: Messaging: New Message: Multimedia: Options: Insert: Graphic (select the photo you want): Send to: Contacts (Me or whatever you used): *note: When you use "Me" as a contact, it may just show "m" on the screen. DO NOT press any other keys. Just send your message to "m", and leave it alone.
Dec 30, 2008 | LG Shine KE970 Cellular Phone
Contacts... broken screen
Menu, 6, 5, 2, 1, OK - at least that is how it is done on my KE970 - copies all contacts from phone to SIM
Oct 21, 2008 | LG Shine KE970 Cellular Phone
Screen cracked need to transfer contacts from phone to sim need perfect instructions
I think u really have to go to a shop that repairs phone but u can try this,u may need patience...i did this onetime and it worked,just try: Find a phone unit which is the same as yours....look for the steps on the other phone (same unit to yours) on how to transfer and do exactly what it takes, just do it step by step. Then try to check ur sim card if the transfer of numbers succeded.
Sep 22, 2008 | Nokia 5300 Grey Cellular Phone
Lg shine
I had the same problem! I just looked up in the manual and the shorcut is menu,8,7,3 to COPY all contacts or menu,8,7,4 to MOVE them (copy keeps the original contacts stored on the handset memory. Now because I can only view the botom right hand corner of my screen I can't be 100% sure what happened next. I pressed (enter/ok). Then could tell I needed to enter a 4 digit code as the layout changed so tried my pin and then 0000. I think 0000 worked and vaguely remeber it as a factory setting security code or summit. Hope it works for you too.
so again I think thats menu,8,7,3,ok,0000,ok......... then wait a few minutes while you imagine the bar scrolling along as the contacts a re copied (took about a minute and a half on mine so maybe wait 3 minutes just to be sure. switch off put ur sim in another phone and see if it worked
if not try your pin in place of "0000"
peace....
May 21, 2008 | LG Shine KE970 Cellular Phone
Tranfering contacts between different sim cards & cell providers
Im afraid you cant do that by transfering ur Fido SIM to Rogers ( since d fone is locked on Rogers Network) one thing i could suggest is use d Bluetooth ( worked perfectly fine for me) Good Luck :)
Nov 30, 2007 | LG Shine KE970 Cellular Phone
Lg shine
there is only one thing i can think of doing, go to car phone shop that sells the phone, have a look at the numbers to the left of all the menus and go from there. it will say For Example, contacts would be 6, copy contacts would be 5 and so on. i have the same problem and i dont know the right numbers so........ but if i find out soon ill let ya know andy
Aug 06, 2007 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
216 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
