Question about Bosch Dishwashers
Bosch dishwasher Water pump not stopping
The water extractor pump does not stop and the timer does not go to 0 sometimes. Stays on 1. The pump seems to run for the last +-50 mins of the cycle. Otherwise seems to wash the dishes ok. Sometimes the cycle has to be reset before starting ok.
Its is almost 8 years old now.
Thanks.
  • Ginko
    Ginko May 11, 2010
    Hi.
    You need to replace the pressure switch located near to the pump, in the drain assembly.
    The main function of the pressure switch is to turn off pump when there is no more water.
    The pressure switch can be tested reading ohms on switch contacts and jumping the switch. This must be done by a technician.
    You can get parts and a quote on repair calling Bosch at the number listed on the manual.
    Regards.
  • Bosch Master
  • 19,396 Answers
Hi.
Regards.
Posted on Nov 21, 2009
SOURCE:
Ffu20fc6aw4
how old is your model you have. a weak pump will make the system slower to get to temp even a broken seal can do this. even just a few mil gap can make it do this. if you close the door then re-open it it should be harder to open the door. this is the seal being nice and tight to its fittings.
Jan 29, 2014 | Freezers
Whirlpool 6th sense stops at 1 min and doesn't finish wash cycle
We had same problem, and the only thing that we could do is call the repair man. He put in a new door lock and the problem was solved.
May 21, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
I have a Bosh Logic dishwasher SGS65L12GB/04 The other day it got to 1 min left and would not stop pumping out water and continued even with the door open. After 5 mins playing around it started working...
Hi Jonathan,
Welcome to FixYa.
Your float may have got stuck or it's possible that you have water leaking into the bottom of the washer. In the bottom of the wash compartment, next to the drain you will find a plastic dome/mushroom (the float). You might need to rotate the bottom spray arm to see it.
Turn the washer on so that the pump starts to run, open the door and push down on the float. This should stop the pump running. When you let go of the float, if it rises back up on its own, then it's almost certain that you have water in the bottom of the washer. If this is the case please post back for further assistance. If the float stays down, then it may have simply got stuck.
Please try this simple test and post back with the results.
Regards,
BElectric
Nov 11, 2010 | Bosch Dishwashers
Bosch Dishwasher stuck at 1
I am currently experiencing a very similar problem. However, I have taken the dishwasher out of the kitchen and plumbed and power it up outside. After tipping the water out of the reservoir on the side, it will start a cycle, it will circulate water. But sticks at 1 minute, trying to pump out water and I'm assuming being told by a sensor that there's water still in the machine. Also I note a small amount of water escaping via the plastic base and water pooling in the base.
Doing the code test shows C2 P0 E1 and then 2 depending on the buttons pressed.
My next task is to get it on a workbench on it's side and take the base off. I'm going to try to trace the source of the water in the base and go from there...
Did you get a resolution?
Did you get a resolution to your probl
Jul 17, 2010 | Bosch 24 in. SGV57T03GB Built-In...
Dishwasher does not complete cycle
The problem is the timer/control. I checked for a recall but your model wasn't on the list. Many of these had a recall for the control, they were a fire hazard. Heres a link to help install the timer/control http://appliancehelponline.com/dishwashercontrol.html. When you remove the front panel there will be to plastic hinge covers be sure to reinstall these they help keep it quiet. They just slip over the hinge. The rest of the removal will be the same.
Jun 02, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Dec 13, 2009 | Bosch Washing Machines
Dishwashers Logo
398 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
