Question about Whirlpool LSN1000LW Top Load Washer
Washer Stuck in Cycle
My whirpool washer will drain but will not move on to the spin cycle untill I pick up the lid and put it back down. Once I put the lid down it will immediatly start the spin cycle. Any ideas on how to fix the problem.
  • Anonymous Mar 21, 2014
    washer goes through all cycles fine and sounds normal until it gets to the spin cycle. i opened the lid and turned the drum just a little, closed the lid and it started to spin and finished the spin cycle. I did hear what sounded like a solenoid click once when i tried to turn the drum. It also started the spin cycle what seemed to be slower than normal and did pick up speed gradually as the cycle progressed.
I checked the lid switch and nothing appears to be broken (cracked plastic). What exactly should I be looking for? Also during the agitator cycle I opened the lid and the washer stopped working. Does that mean that the lid switch is working?
Posted on Jan 14, 2008
How do I know if my lid switch is bad. Nothing appears to be broken (cracked plastic). Also during the agitator cycle I lifted the lid and the washer stopped.
    President:
  • 1,314 Answers
Yes check your lid switch for proper contact and operation the plastic holders on the switch are bad about one side breaking or cracking hold my rating till you inspect it in case you need repair info will walk you through it
Posted on Jan 11, 2008
  • 589 Answers
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
Aug 26, 2009 | Whirlpool Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Sometimes the spin cycle works and sometimes it doesn't. The water is draining, but sometimes the clothes are still very wet and I have to wring water out of them before I put them in the dryer.
if that is a top load whirpool suspect transmission..the transmission is designed to drain first and then after another timer pause go into spin sometimes after the pause they fail to do so it is a hard problem to verify without a lot of patience..put washer into final rinse allow washer to complete cycle on it's own DO NOT MANUALLY ADVANCE TIMER OR OPEN LID if possible you can raise lid and hold lid switch down.. after agitation there should a short pause then pump out then another pause and spin should engage if you do not here spin raise lid then shut if spin starts change transmission..on rare ocassion have seen timer never pause then change timer if this is only occasional may be hard to spot and may require more than 1 attempt to catch it..good luck
Sep 07, 2008 | Washing Machines
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
179 people viewed this question
Dan Webster
Dan Webster
Sal De
