How do I repair my Toshiba satellite pro? It stops booting at the ''toshiba leading innovation'' screen and wont go any further. Ipressing F2 or F12 has no effect so I cant acces my bios or get the laptop to boot from a cd. any help you can give would be much appreciated, thank you, Peter
    Sergeant:
    Champion:
  • 212 Answers
Try a different hard drive. Or try to boot with the hard drive out. If that dont help its probably the mainboard. Good Luck.
Posted on Nov 20, 2009
Testimonial: "I Have tried this and nothing happens. Toshiba have now agreed to pick up my lap top under waranty and look at it, Thank you, Peter"
Hello, the problem with my mini toshiba nb200 is that when I on it, it shows the initial screen which says ; TOSHIBA Leading Innovation >>> Press [F2] for ...
If you are getting the Toshiba Select F2 or F12 screen the mother board has finished with POST.
Toshiba laptops are very good normally but don't boot up if there is a device in the USB slot or a CD/DVD in the drive.
If it still refuses to POST, remove the AC Adapter, remove the battery and remove the hard drive.
Power the unit up without the hard drive and it should complete POST and complain that there is no hard drive. If that doesn't work remove AC adapter, ensure battery is disconnected and remove hard drive and RAM. Try again. If it still doesn't work, you have a mother board fault and it needs a service centre. www.Toshiba.com will help you out.
If it does work at one of the options, when you have closed the laptop down, replace the RAM first and test, then the Hard Drive.
Hope this fixes your problem.
Feb 05, 2011 | Toshiba Satellite A205-S4617 Notebook
My Toshiba Satellite pro s300 ez2501 , is being stuck and fan should run fastly with rough sound, we cant do any thing at this time, only function key can work but nothing will happened.
This is an open ended question as I am not aware of your problem, however,
Disconnect your power supply and remove the battery.
Refit the battery and plug in the AC adaptor, check the power light and battery light are illuminated.
Keep disconnect any periferals, (USB devices) and ensure the DVD drawer is empty. Press the power button. The POST should now start up flashing a line of led's across the top of the keyboard first followed by the hard drive light.
The BIOS F2 or F12 choice screen will now appear. If it doesn't the laptop hasn't completed POST and can go no further however, if it gets that far;
Press F12 and select Hard Drive for the boot device, the laptop will then try and boot from the hard drive, just as the boot chioce menu dissapears press F8, this will opem a further menu allowing you to repair your system. This, if selected, will collect data stored on drive E and repair the main system putting the OS back as it was when you first purchased the machine.
If that won't work or there is a corrupt file or serious error, you will require an OS system disk.
Place the System disk in the DVD drive, press power until the system tries to boot and when you get to the boot selection menu, press F12 again but select CD/DVD as the boot drive.
Follow my last instructions again and you will have a fresh/repaired system and a working laptop again.
When all is OK go to www.computers.toshiba-europe.com and let toshiba download and install the latest drivers and BIOS.
Hope that helps.
Nov 25, 2010 | Toshiba Satellite Pro S300-EZ2501 Laptops
When I turn the laptop on (L350) the screen starts with the "Toshiba leading innovation" page then is blank- dark grey. It does not respond to any keys including F2/F12
The laptop can not detect the hard drive please remove the hard drive and then reseat it if the problem persist then replace the hard drive.
Feb 07, 2010 | Toshiba Satellite Pro L350-S1001V Notebook
Blue screen with windows xp can't boot from cd
Most toshiba will boot if you press F12 and a boot screen will appear . the bios is most of the time acessed through F1 or F2 try that and let me know what happens
Nov 07, 2009 | Toshiba Satellite A135-S2246 Notebook
When i turn on laptop the toshiba leading innovation comes on then the screen goes black/darkblue then nothing
first you have to do is entering bios by pressing "F2" or "del" tab, check the primary bios setup is your hardrive detected or not, if it is detected then go on...
second, still from the bios, configure the boot priority, mark harddrive as the first primary booting...
if it is not work, then u have lost OS, could be infected by virus or some missing program..
in the case u have to reinstall/format your OS
Jun 28, 2009 | Toshiba Satellite Pro L300 Notebook
Cmos / Bios password
IF IT COMES TO A SCREEN THAT SAYS "TOSHIBA" AND AT THR BOTOM LEFT SAYS ''F2-UTIITY , F12- BOOT MENU'' CLICK F2 IMIDITLY AND USING THE RIGHT CONTROL BUTTON SCROLL TO ''SECURTY'' AND CHANCE THE PASS WORS
Apr 03, 2009 | Toshiba Satellite Pro L300 Notebook
How do i format satellite pro 4600
Caution: formatting the will lead you to loose all the data on your computer.
To format the drive you need to boot from the cdrom/dvd drive
to boot from the cdrom/dvd drive you will need to chnage the boot sequence you will need to tap the F2 key at the toshiba logo and here you can change the boot sequence or try tapping the F12 key at the toshiba screen to enter one time boot menu here you can select the drive you want to boot from for one time only and to reinstall windows here is one helpfulll ink
http://www.windowsreinstall.com/
Further queries are welcome
Please do rate me if you find my solution helpfull
Mar 17, 2009 | Toshiba Satellite Pro 4600 Notebook
Won't boot up
A bit more info would be good. Did it shut down normal. can you enter bois. any messages???
Dec 06, 2007 | Toshiba Satellite M115-S1061 Notebook
Computers & Internet Logo
372 people viewed this question
David Payne
David Payne
