Question about Toshiba Audio Players & Recorders
Window will pop up and say replace weak battery or switch to a/c power. how do i do that?
    Guru:
  • 1,738 Answers
You must have a battery backup on your system. You battery must be going bad, and windows is saying you need to replace it. Sometimes you can get lucky and get them for cheap and sometimes very expensive.
Posted on Nov 21, 2009
Power window
didnt specify vehicle -generic answer -pop out switch and test for power and operation if no power to switch will need to check harness -if power to but not after switch replace switch--good switch will need to remove door panel and test window motor /egulator
power window problem Yahoo Video Search Results
Sep 04, 2016 | Cars & Trucks
My kia sportage 1998 power window very weak cannot lift the window need to be pushed by hand. Do i need to replace the power window switch?
if you have to assist the window when operating the window motor it sounds like a bad motor armature/brushes. replace the window motor.
Nov 02, 2014 | Cars & Trucks
Ford F 250 , power windows
Window glass movement is got dusty and needs basic servicing.Or its weak motor or faulty switch.But as you mentioned it works when you help the window to get up,these says its not switch or fuse,but motor can be weak or there is dust issue causing these.----------
Check out the solved help link with these types of problems.
Car Power window troubleshooting:
http://whoisbyme.blogspot.in/2012/05/car-window.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Audi battery replaced whit new battery electic windows not working tryed fueses still no joy
im not sure what year or make this audi is but some will loose the programing and need to be reprogramed, the dealer does this, but if the windows had a problem before the battery replacement then there good be a problem with the driverdoor window switches, if that switch goes bad then no window will operate, pop switch up and test for power to switches, also make sure all wires are connected back on to the battery and that nothing was pulled apart. good day.
Jul 30, 2011 | Audi A4 Cars & Trucks
How do I replace the power window switch
if there are screws, unsrew them and take out the panel. then unhook the switch and unsrew that. replace opposite. unhook battery first. if no screws, they snap in place, using a small screwdriver, gentely pop out.
Aug 21, 2010 | Chrysler Cirrus Cars & Trucks
On my 02 Totyota Avalon when I turned the key to start the engine there was a sound like a pop and then it wouldn't start. Then there was nothing, it was like the battery had died although there had been...
Remove the battery and attempt to charge it, then have the parts store perform a free battery test. You likely just need to replace the battery and the pop was an indicator that a dead short in the battery is draining off the electricity that would otherwise be stored in the battery. If you don't know the age of the battery that means it's probably not new and typically 3 years (or more if a very expensive battery with duration of up to five years is selected) is the typical life of a car battery.
Jul 25, 2010 | 2002 Toyota Avalon
Power windows quit replaced fuse under hood replaced fuse inside still have no power windows
#1 so many people make the mistake of pressing the window lock switch on the drivers master window switch, double check to be sure it is not engaged. If that is not the problem you can pop the master switch out with a small flat tipped screw driver & check for power with a test light. If power is going to the switch & the windows still won't work, replace the master switch. good luck
Mar 20, 2010 | 1998 Ford Explorer
97 isuzu trooper. Starter motor has no power.
Check the battery and cables going to the starter. Weak arc? Possible that the relay needs to be rechecked now. The inertia switch may also be a possibility. Has the car been in a recent fender bender?
Sep 12, 2009 | 1997 Isuzu Rodeo
32 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Electro Med Services...
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
