Question about Nintendo DS Lite Console
When you have to touch a button on the screen you have to touch the top left hand corner, otherwise the consolte will not register you have touched the button or you end up touching a different letter e.g. if the alphabet is shown. Can this be fixed?
Yes, you need to calibrate the touch screen. If that doesn't work, the touch screen might need replacing but it's pretty easy to do and they are normally only £5 on ebay with free p&p. I know because I just had to replace mine! :o) There are also some really good videos on YouTube which provide step by step instructions on how to replace it. Good luck!
Posted on Nov 21, 2009
Cm6040 unlock menu
Navigate the Administration menu
From the Home screen, touch Administration to open the menu structure. You might need to scroll to
the bottom of the Home screen to see this feature.
The Administration menu has several sub-menus, which are listed on the left side of the screen. Touch
the name of a menu to expand the structure. A plus sign (+) next to a menu name means that it contains
sub-menus. Continue opening the structure until you reach the option that you want to configure. To
return to the previous level, touch Back.
To exit the Administration menu, touch the Home button in the upper-left corner of the screen.
The device has built-in Help that explains each of the features that are available through the menus.
Help is available for many menus on the right-hand side of the touchscreen. Or, to open the global Help
system, touch the Help button in the upper-right corner of the screen.
The tables in the sections that follow indicate the overall structure of each menu under the Administration
menu
Aug 13, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
I would like to remove My Tom from my iPad.
On the main menu screen touch and hold the app you wish to delete until an "x" appears at the top left hand corner. Press the "x" to delete, and then hit the square button (the only button other than the power button) to resume normal use.
May 16, 2014 | Tablets & eReaders
How can i reset my ipod?
Please follow the below steps to reset the iPod.
  1. Press and hold the "Sleep/Wake" button. This is the main power button on the top left-hand corner of the device.
  2. Press and hold the "Home" button while still holding "Sleep/Wake." The home button is the main button on the front of your iPod touch, indicated by a white square inside of a circular black button.
  3. Hold both buttons until the Apple logo appears on your screen. Resetting can take upwards of 10 seconds. Once the logo appears, your iPod touch reboots by itself.
Thanks for understanding.
Dec 30, 2011 | Apple iPod touch
My mouse touchpad is locked. Keeps showing a diagram on screen with a red line thru the touchpad??
There may be a button towards the top of the keyboard (one of the ones with LEDs next to them) that turns the touch pad on and off. Otherwise, there is usually a keyboard combination (the Fn key in the lower left + one of the F1-12 keys) that can toggle it on and off as well. Otherwise, in the lower right hand corner, if you plug in a mouse, you should be able to right click the touchpad icon and re-enable it.
Aug 23, 2011 | HEWLETT-PACKARD ProBook 6460B
Garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Apr 09, 2010 | Garmin nuvi 1350 Car GPS Receiver
When i turned on the leapfrog and asked me to log in my name it doesn't let me go in when i press it with the leapfrog pen
the screen needs to be re-calibrated. Do this: while powering on the Leapster, hold down the ? key. If it's been worn off, it's the round key on the left hand side above the t-arrow keys and it's the middle button. A new screen will come up that lists Base Info Cart 1 Info, Cart 2 Info, Cart 3 Info. In the right hand corner is a "A" that you can touch with pen beside it, it says "Touch Calib" Touch on that.It will say starting...then in the upper left hand corner there is a +. touch it with pen. it will move to bottom left hand corner. Touch it with pen. It will move to right bottom corner. touch with pen. It will move to upper right hand corner. Touch with pen. It will move to the center of the screen. Touch with pen. Repeat until you come back to the Base Info screen. You're DONE! Power off and on again and you should be all set! Good luck!!
Feb 28, 2010 | LeapFrog Leapster 2 Learning System
Touch screen issues
Has the unit ever been really wet or is there a hole in the touch screen foil? If not have you ever done a cold reset?
. First turn the unit OFF, then HOLD your thumb on the furthest bottom right hand corner of the screen, push as far into the corner as you can on the screen itself. While holding your thumb/finger on the screen press and hold the POWER ON button until you see the ZUMO splash screen, once the splash screen is up you can release the power, but continue to hold your thumb in the right corner of the screen for another 5 - 10 seconds, you should see a window that pops up and asks "Do you really want to erase all user data?", make sure to answer YES to this window, if you don't see this window, then turn unit OFF and try the above instructions again, ensuring your thumb is in the furthest portion of the bottom right hand corner of the touch screen.
Jul 23, 2008 | Garmin zumo 550 GPS Receiver
Set up e-mail address in Canon 5020i
1) press the * (star) button with the head shape around it
2) on the screen touch on "Address book Settings"
3) Touch on "register address"
4) Touch on "E-mail"
5) in the bottom left hand corner of the screen touch on "Register New Address"
6) Touch on "e-mail"
7) Touch on "name" and enter the recipients name and press "OK"
8)Touch on "e-mail address" and enter the recipients e-mail address and press "ok"
9) Touch on "ok" again
Repeat steps 6 - 9 to add additional addresses otherwise touch on "done" 4 times to exit the menus
If you wish to register the e-mail addresses in the one-touch address book, follow the steps below:
3) touch on "one touch buttons"
4) touch on an empty block
5) touch on "register/edit"
6) touch on "e-mail"
7) touch on "name" and enter the person's name and press "ok"
8) touch on "one touch button name" and enter the person's name again (here you're restricted to 12 characters so you may need to abbreviate it somehow) and press on "ok"
9) touch on "e-mail address" and enter the e-mail address and press "ok"
10) touch on "ok"
repeat steps 4 - 10 to add more addresses. or touch on "done" 4 times to exit the menus.
May 09, 2008 | Office Equipment & Supplies
Cannot align the touch screen
look for a tiny pinhole and insert a pin while powered up to reset the device
May 27, 2007 | Lanzar (STDIN70) Car Video Player
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
