Question about RIM 8700c Smartphone
Old Emails sent as New
My Old emails are being sent as NEW. Its very confusing, I am end up answering messages that I responded to long ago.
I called Tech support but they didn't offer any solutions.
  • 78 Answers
SOURCE: Black Berry 7250 not allowing me to scroll or answer calls
Sounds like you need to do a hard reset on the device. Try pulling out the battery while the device is on, leave out for 15 seconds and then put back in.
Posted on Jun 03, 2008
0 characters
1 Points
Need email setting for nokia n81 incoming and outgoing
Hello :
Here are the instructions :
Setting up email:
1:From the standby screen, press the Messaging softkey . Altenatively, press the Menu button, and highlight Messaging .Press Open.
2:Scroll down to highlight New mailbox .Press Open.
3:A message appears: No mailbox defined. Define now? .Press Yes.
4:Instructions appear for the email wizard .To start the email set-up wizard, press Start.
5:In the email address box, type in your full email address .Press OK.
6:You can now type in the name you want to call your email mailbox, or leave it as the default name of your email service .Press OK.
7:You are asked to define the user name and password for your account . Press Yes to continue.
8:In the User name panel, edit the email address until you have your user name - this is usually the bit of your email address before the '@' sign, (though if you're unsure, check with on your email service provider's website).
9:When completed, scroll down using the navigation pad to highlight the Password panel. Type in your email account password . Press OK.
10:After a few moments a message appears onscreen informing you that the email mailbox has been defined .Press OK.
11:The first time you set up, you will be taken into your mailbox and asked: Connect to mailbox? . Press Yes.
12:After a few seconds while the phone connects, you will get a list of email message subject headers onscreen . Scroll through the list to highlight ones you want to view.
13:Press Open to download and view the full email. Scroll down to read the message .
14:If the message has an attachment, scroll to highlight it and press Attachments . Highlight the attachment and press Open . You'll be able to see the attachment in full . Press Close and Back to return to the original email.
To get back to your mailbox, press Back. Alternatively, if you want to reply, forward or see other options, press Options. A list appears onscreen .
 Replying to emails:
1:To reply, highlight Reply. Press Select. Highlight To sender .Press Select.
2:Type in the text of your message. You can also edit or delete the original message if you want to, add new recipients or alter the subject header .
3:When you're ready to send, press Options, highlight Send and press Select .
4:Alternatively, before you send the message you can add an image or other files by selecting Insert from the Options list and pressing Select .
5:A row of icons appears at the bottom of the display, representing different elements you can insert - images, others, video clips, sound clips or text . Highlight and select one of these, and you can search through files to add a suitable attachment. Press Select to add it to your email.
6:When ready to send, as before press Options, highlight Send and press Select .
Checking for new emails :
1:To check for new emails go to the Messaging menu as before .
2:Scroll down to the name you gave your email mailbox . Press Open.
3:If you're not currently connected, you will be asked if you want to connect to your mailbox . Press Yes. New messages will now be retrieved.
4:If you are already in your mailbox and want to check for new messages, press Options, scroll down to Retrieve email .Press Select.
5:Highlight New . Press Select. New messages subjects will be delivered to your mailbox.
Sending new emails:
You can send messages as emails as quickly and easily as text or MMS messages.
1:In the Messaging menu, highlight New message .Press Select.
2:Scroll down to highlight E-mail . Press OK.
3:Add the email address, subject and message .
4:If you want to, add any attachments in the way outlined above.
5:As before, when your email is ready to send, press Options, highlight Send and press Select .
good luck .
rate please !
Mar 18, 2010 | Nokia N81
My blackberry shows unread email icon when I dont have any
Check in the SMS and MMS icon for a new Text, or Voice Mail Message Indication. If you can not locate an unread message in the SMS or Voicemail, then try removing and reseating the battery to reset the device and resync with your Provider's Network.
Nov 17, 2009 | RIM BlackBerry Curve 8310 Smartphone
The G1 is not good
All mobile phones have email address. You can sent emails to your friends mobile phones, can you? So if you can send emails to friends, then you can send photos to them and to any other mobile phone and computers, as long as you have the email address of those you wish to send them photos. Do this. if your old phone has a Photo and Video library (yes, you must have, its in the phone, check it.), better still, does your old photo have a camera? If so, then you have a Photo and Video Library. Go to Photos, find and click 'Viewer', small thumbnails of photos appear. Select the photo to wish to send to any other mobile phone, the press 'Send'. Depending on the brand you have, in this case an LG phone, a window appears, asking you if you want to send the photo via Multimedia msg, Email or Bluetooth. Select Email and click OK button. Another window appears with the To: If you havestored phone numbers in the old phone, together with friends email addresses then click Ok button again and it takes you to another window with a list of your friends addresses. select any one and then you 'Mark' the photo first with a check mark. then you probably have to press 'Done'. After done this, you can press Send and voila. the photo is being transmitted to air. If you want to do the same procedures, such as sending the photos to your new phone, all you have to so is select not your friend's name but your own name in the old phone. If you have ever sent a photo to your PC, note that special email address. Use that address and see if it sends the photo to the new phone. Usually it does. If not, the phone provider will tell you what email address your phone has.
Sep 18, 2009 | HTC G1
My blackberry was receiving emails fine earlier this morning, but as of about lunch today, it has not received any emails. I have received them on my laptop, so I know that there have been emails. Im a...
Emails for BlackBerry go through their own server network to be sent to your phone. It is possible BlackBerry had an outage. If that's the case, they should resume soon.
Also try to restart the phone and check your settings to see if they are still accurate.
Sep 09, 2009 | RIM BlackBerry 8700g Smartphone
Email unread icon on home screen always shows 2 unopened
I had the same problem If you SAVE any messages they move to your SAVED folder they will show as new just go into the file cabinet icon and see if any messages are there all you do is open them and the icon should go away
May 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry Curve confirmation emails
Call your service provider and tell them to turn it off.
Jun 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
Verizon pearl
Have you checked your memory space? If yor running low on memory the phone will automatically delete call logs and possibly messages in order to make more memory available. If you have a memory card installed try moving your pictures and all the other extemporaneous files to the memory card and see if your problem continues.
Jun 17, 2008 | RIM BlackBerry Pearl Smartphone
Will receive emails but not send them
I have exactly the same problem; phoned t-mobile; it's a problem at their end, they are hoping to resolve shortly
Jun 10, 2008 | T-Mobile MDA Vario Smartphone
May 26, 2008 | RIM BlackBerry 7250
Send/receive emails
delete your email settings and start over. If I am right, you just recently changed or setup this account..???
- make sure your using the most current settings.
GOOGLE - outlook settings for GMAIL or what ever provider your entering in. You may have had some issue at setup.
May 24, 2008 | T-Mobile Dash Smartphone
RIM 8700c Smartphone Logo
64 people viewed this question
Top RIM PDAs Experts
Nataly Roberts
Nataly Roberts
Martin Murray
Are you a RIM PDA Expert? Answer questions, earn points and help others
