Question about Hotpoint RB757 Electric Kitchen Range
Broiler element replacement
Need to replace broiler element,is it just unscrewing and replacing?
  • Anonymous Mar 20, 2008
    fridgidaire pleb27t8ccb broiler replace-can I unscrew and remove from inside oven?
    President:
  • 1,314 Answers
Pretty much be sure to turn the breaker off first some you can do from in side the oven some you have to pull the back panel try from inside first remove the screws then see if you can pull the element through enough to plug and unplug the wires if not then you will have to remove the back panel to un plug the wires either way no biggie i appericate your rating that will fix it
Posted on Jan 11, 2008
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Broiler on oven not working
Remove the broiler element and check it for continuity with a multi-meter. If it fails the test, replace the element with this part.
If the element test good, you need to replace the control board. Here is that part to order.
Feb 17, 2013 | Frigidaire PLEFMZ99EC Electric Kitchen...
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
Broiler doesnt heat up but bake element at bottom of oven doe. Everything is getting power. How do I replace the broil element if that is the solution?
It may be the element, however there are a number of other faults that could couse your problem.
The element would typically have screws on the base plate and would be supported in some manner. TURN THE POWER OFF before attempting any repairs.
Find the suppoprts and unscrew/remove. Unscrew base plate screws.
The elemenr should be able to be removed and the wires unplugged.
Test the element and if it is not faulty, call a service guy!
Nov 21, 2009 | Kitchen Ranges
Kenmore electric stove oven top element (broiler works but bottom element will not heat
the element is easy to change. just slide out the stove from the wall. take off the rear cover and just unplug or unscrew the leads from that element and replace. first make sure you unplug the stove it's self from the wall. it does have 220 volt and will hurt you.
Sep 05, 2009 | Kitchen Ranges
Replace broiler heating element Whirlpool builtin oven
do you want to know how to replace it? turn the power off first. open the door to the oven usually there are 2 screws that go to the broiler. unscrew them pull the heating element out remove the wires, make sure you pull them out far enough or you will loose them in the back of the oven. plug the new one in screw in the screws and you are good to go. let me know if this helps
Jul 18, 2009 | Ovens
The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
Jul 13, 2009 | GE Spectra JBP78 Electric Kitchen Range
General electric model spectra XL44 stove not heating but broiler works
you need to change the bottom heating element . you can unscrew it and take it to home depo or appliance store and get a replacement and screw it back on should work fine then.......
Jul 11, 2009 | Kitchen Ranges
Hotpoint RB757 Electric Kitchen Range Logo
112 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
