Black & Decker DF250 Cool Touch Deep Fryer
Problem for Black & Decker DF250 Cool Touch Deep Fryer
Deep fryer wont heat up
By DPruder on Jan 11, 2008
hello i have a deep frier that wont heat up. The heat ligh tis on when i take the switch to the lowest setting the light goes off.
Same Problem
Jan 13, 2009
-   will not heat up to desired temp-   Guest
Best Solution
posted on Feb 19, 2008
Very Helpful)
jerrodb
Rank: Wiz
Rating: 81%, 104 votes
I have the exact same deep fryer and it was doing the same thing if you take out all of the oil and clean it realy good it should work again
Was this helpful?
Yes
No
Popular Solutions for Black & Decker DF250 Cool
Questions and Unsolved Problems for Black & Decker DF250 Cool
Do you recommend Black & Decker DF250 Cool Touch Deep Fryer?
Answer
Answer
i need cored to plug in fryer its a masterbuilt electrict fryer
Answer
i have a gas wall oven model# 911-30169690. When i set oven a locked door flashes and turns oven... (More)
Answer
with the new t-gfi 20a and the new yellow 12/2, does a person have to run 2 runs of 12/2?
Answer
Flu fire, I needed to get carbonized grease that is inside of the flu
Answer
i have a similar problem........the problem is in the heating unit underneath the oil container. if... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Black & Decker DF250 Cool...:
Top Deep Fryer Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Deep Fryer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
