Question about Dell Studio 1537 Laptop
How to reseat my bluetooth. I went to the set up menu and my bluetooth says "enabled" but for some reason the computer isn't able to fine it.
  • 56 Answers
Goto control panal you can change it from there
Posted on Nov 20, 2009
Need to connect to my I pad
What are you trying to connect?
If it's your Mobile:
On the Phone:
1. Select the option to enable Bluetooth Tethering.
2. Enable Bluetooth on the phone.
3. In the Bluetooth menu, make the phone discoverable by tapping the top message.
On the iPad:
1. Turn the Bluetooth on in Settings.
2. When the phone appears on the list of devices, Tap to connect.
That should do it.
Jan 12, 2018 | Computers & Internet
I have alcatel z221 cant download pictures to computer
You can transfer pictures from your phone to your computer in 2 ways.
Bluetooth
1. Enable Bluetooth
- From idle mode, select Menu > Settings > Connections > Bluetooth.
- Press the OK Key to set Bluetooth to On.
2. Pair your phone to your Bluetooth enabled computer. If your phone does not have a built-in Bluetooth module, you can buy a Bluetooth dongle from your local electronics store.
- From idle mode, select Menu > Settings > Connections > Bluetooth > My devices.
- Press the OK Key to search for available Bluetooth devices.
- Highlight a device from the list and press the OK Key.
3. Select your desired file, and select Left Soft Key [Options] > Send > Via Bluetooth.
4. Select the target device from the device list, and press the OK Key to send.
Email
1. Select your desired file, and select Left Soft Key [Options] > Send > Via Message
2. Enter your email address. press the OK Key to send.
3. You can now download the file from your computer.
Aug 31, 2015 | Alcatel Cell Phones
How do i enable blutooth
I believe that device uses the android os. You should be able to access the bluetooth settings (assuming it has bluetooth capabilities) from the settings menu. Normally you go to your home, click menu then settings. If yours has a connection tab, choose it. There should be a bluetooth option to toggle on/off.
Aug 18, 2014 | Craig Electronics Recertified - Craig...
Asus laptop how do you get no wifi
Turn on your computer and locate the Wi-Fi icon.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on.
When you turn on an Asus laptop's Bluetooth function, you allow cell phones, headsets and any other Bluetooth device to be synced with or found on the laptop.
You can use Bluetooth on a laptop to listen to music on a headset or to sync and transfer files from the computer to the device.
If the Asus laptop has Bluetooth wireless technology preinstalled, you can enable Bluetooth access by changing the settings in the control panel.
Click the "Start" menu and open "Control Panel."
Select "Hardware and Sound" and "Bluetooth Devices."
If the "Bluetooth Devices" option doesn't appear, your laptop does not have Bluetooth capability.
Open "Bluetooth Settings."
Click the "Allow Bluetooth devices to find this computer" checkbox in the "Options" tab.
Click "Apply" to save your settings. Click "OK" to close the window.
Change settings for a Bluetooth enabled device
http://windows.microsoft.com/en-US/windows7/Change-settings-for-a-Bluetooth-enabled-device
Jun 10, 2013 | Acer Computers & Internet
How can I on the bluetooth on my laptop aspire 4743Z?
Connecting your Bluetooth wireless phone with your laptop is called pairing, and I'll use a Blackberry Curve to show you how it works. I'm assuming your laptop comes with a built-in Bluetooth adapter (or you can also get a Bluetooth adapter that plugs into one of your USB ports).
First make sure that Bluetooth is enabled on your phone. For Blackberry phones, that means selecting the "Set Up Bluetooth" application from the main screen, and then selecting "Enable Bluetooth" after clicking the menu button.
Next, set up your computer to allow Bluetooth connections. If your computer comes with Bluetooth, then you'll see a Bluetooth icon in your Control Panel (Start button -> Control Panel from Vista):
control-panel-bluetooth.jpg Double-click the Bluetooth icon and you'll see a Bluetooth Devices dialog. Click the Options tab and make sure the options to "Allow Bluetooth devices to find this computer" and "Allow Bluetooth devices to connect to this computer" are both checked
bluetooth-devices-options.jpg Next, click the Devices tab and then click the "Add" button. This will open the Add Bluetooth Device Wizard, and after verifying that your device is set up and ready to be found (ie. Bluetooth has been enabled on your wireless phone) it will try to find your phone.
add-bluetooth-device.jpg Select the Bluetooth device and click Next to set up a passkey, which is a number that associates your computer with a Bluetooth enabled device. For security reasons, most Bluetooth enabled devices (with some exceptions, such as mice) require you to use a passkey. Using a passkey helps ensure that your computer is connecting to the device that you intended and not someone else's device that is nearby.
You can choose your own passkey or let Windows choose one for you. Click Next and then pick up your phone, which will prompt you to enter in the passkey. After entering the passkey in your phone, Windows will finish the pairing process and your phone will be connected via Bluetooth.
May 10, 2011 | Acer Aspire 5742Z-4200 Notebook
How to copy the mobile messages to computer?
One simple solution is to simply forward the message to an email address you use on your computer and saving it to a folder.
There is no option in the Samsung messaging system to "share" the message directly. So to get around that, go to the message, open it, click the menu button, where you can forward to another email address that you can open and save in your computer emails.
Or you can open the message, click menu and pick "copy message text", go into any number of note apps that Samsung has installed or that you can download from the Android market. Paste the message there, then click the menu button in the notes app and pick "share", you will have many options, but pick bluetooth and send the message to your computer via bluetooth. Make sure your bluetooth is enabled on your computer and on your phone.
On your computer go to start, then type in Bluetooth (or go to control panel and pick the bluetooth icon). Enable bluetooth to receive. Go into your Samsung "settings", pick "wireless and network", pick "bluetooth", pick "visible" and either scan for your computer or have your computer scan for your device. When they are connected, you can transfer the saved message to your computer.
Once your Samsung is paired with your computer and you have the hang of saving the message to notes, clicking the menu, click share, click bluetooth, transferring your messages will be quick and easy.
Jan 01, 2011 | Samsung Computers & Internet
Need password to use bluetooth on my samsung a920 cell phone
To turn Bluetooth on: 1. Select Menu > Settings > Bluetooth> Enable. 2. Press the navigation key up or down to select On and press to enable Bluetooth. To turn Bluetooth off: 1. Select Menu > Settings > Bluetooth> Enable. 2. Press the navigation key up or down to select Off and press to disable Bluetooth.
PW try these: 0000 000000 1234 123456
Dec 15, 2010 | Samsung MM-A920 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Want to send picture from phone to computer
Can you not use bluetooth to send pictures from phone to computer. Search on your mobile phones menu to see if there is bluetooth and enable it. If your mobile is not bluetooth enabled, you may still be able to send pictures from phone to pc if there is a USB cable slot in the phone. To send to the pc via bluetooth, either your pc has been set up with bluetooth, or, if not, you have
to install bluetooth using a bluetooth dongle which comes with CDrom, and may be purchased from computer stores like Currys or online for £10-15. Let me know if you have bluetooth, and I'll help you more. Once there is Blue tooth it needs to be turned on, and discovery mode has to be enabled, (not disabled) in order to communicate with other nearby bluetooth enabled devices. Get back to me tell me what you found out, Good luck papertigers
Dec 13, 2008 | RIM BlackBerry Curve 8310 Smartphone
My Katana and Bluetooth
Some devices require you to set the device for recieving data. In the Bluetooth, menu there should be an option to "Receive File" or photo.
Mar 31, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Dell Studio 1537 Laptop Logo
94 people viewed this question
Alun Cox
