Question about Filter Queen Majestic Canister Vacuum
Filterqueen cuts out when warm
I have a 27 year old Filterqueen that runs for a few minutes and cuts out. Once it cools down, it starts up again. I've checked the brushes, which seem ok. It's not the main switch because the power nozzle keeps working even when the main suction motor quits. Is there an overheating switch somewhere?
  • bikermike Jan 12, 2008
    I have checked the secondary filter disk and do replace and/or clean it regularly. However, I've ignored the top filter for years. I'll give that a try. I was unaware there is a temperature switch built into the motor. Thanks.
    The top filter and worn brushes were the culprits. Thank you.
  • 126 Answers
You should check the disc filter that is located under the paper cone support. The support is secured with a single screw in the middle at the bottom. This filter is commonly overlooked and when it gets dirty will restrict airflow and cause the motor to overheat. Most motors have a Hi-Limit switch incorporated into the motor to protect against overheating. You should also check the top filter (which is probably foam) and replace if it is clogged.
Posted on Jan 12, 2008
Zip brush won't spin and I can't figure out how to fix
did you check to make sure theres no clog in the hose since its powered by air?
Aug 09, 2011 | Kirby G4 Bagged Upright Vacuum
My old DC02 runs for 5 to 10 min before overheating and cutting out. Once it cools down it go backs to working. Any suggestions?
DC02 is fitted with a thermostat designed to protect the motor. If your machine is cutting out after a few minutes of use, you may need to wash the filters. You can view a video demo of this procedure on the Support section of our website:
It's also a good idea to check the cleaner for blockages - you can find out how to do this here:
You should find this resolves the problem. However, if you're still having difficulties, please get in touch with us free on 08002980298, so we can run through some checks over the phone.
Kind regards,
Dyson Customer Service
May 09, 2011 | Dyson Vacuums
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
Ihave a filterqueen majastic its about 10-12 years old and last week the motor seems to not work with full power. what seems to be the problem?
Our filter queen experienced a loss in power. Once we replaced all the filters and cleaned it all out, it worked well again. i think a filter kit cost about $80, but that was a while ago.
Nov 01, 2009 | Filter Queen Majestic Canister Vacuum
Stops after a few minutes
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Run cut off -run cut off every ten minutes
The TOC(thermal overload cutout) on the motor is getting too hot - thats why it keeps shutting off and starting again once its cooled, so make sure your filters are clean and they are no blockages in the hose or the brushbar compartment or any where else
Which dyson is it?
Aug 31, 2009 | Dyson Vacuums
Cutting out after five minutes use
sounds like not good air flow check for blockage new filter
Aug 11, 2009 | Vacuums
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Filter Queen Majestic Canister Vacuum Logo
232 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
