Question about Nokia 2760 Cellular Phone
I want a nokia sound code to make my phone louder
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
My nokia screen not working
Enter the following code:
*#8999*8378#
(You'll be shown menu, then ...)
then go to:
"H/W test"
then go to:
"Audio Settings"
then go to:
"Melody Gain"
There will you see a number.
there are five (5) Melody Levels" of it.
(and currently, you are at level 1 and after
pressing the "save" button, you will move to
level 2 and so on .........................)
you have to change the values of all the levels.
and as the resultant, it will give increase the
melody sound!, your tones will more louder,
even more louder then the max. ringing volume.
the level wise numbers are: (as its my setting :-) )
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
you even can make your own combinations of level wise
sounding numbers that can change the sound level!.
if your combination cause more louder sound level,
then mine,
then do share it with the group! ... :-)
meanwhile, try my figured-out combination!
************ CAUTION ************
if anything goes wrong,
then you can apply the master reset code,
that will NOT delete anything, ANYTHING from your
cell fone, but set each and eveything to its
default/standard setting ...
(likes, factory settings :-) )
the master reset code is:
#*7728#
Feb 14, 2012 | Nokia C601 Cell Phone
Can you make my nokia 6300 louder please ?
I cannot make it louder for you but you can go into your menu, settings, sounds and select the sound setting that you wish to have. If you still have the owner manual it will tell you how to do this and if you don't have it or if you can't do it by yourself thru the menu, take it to your service providers store and they will set the sound louder for you.
I hope that this helps you and please do not forget to rate/vote and place a testimonial on my advice.
Wicked Angel
Nov 19, 2010 | Nokia 6300 Cellular Phone
Nokia 5310 sound
Try going to
Menu>Setings>Call>Voice clarity>Active
Hope it works
Apr 11, 2009 | Nokia 5310 Cellular Phone
Nokia 6300 not very loud
U just set the equilizer to CLASSIC , Then see difference.
Dec 07, 2008 | Nokia 6300 Cellular Phone
My speaker on my nokia 6300 isnt loud enough can u help me with codes
See i dont think so there is any code for making the sound louder. But using the music player "KD Player". the will be a little higher.
Nov 04, 2008 | Nokia 6300 Cellular Phone
Nokia N95 - Loud Beeping Sound when making calls
It could be that you are accidentally activating the voice recorder.
Apr 27, 2008 | Nokia N95 Cellular Phone
Nokia 2760 Cellular Phone Logo
3,884 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
