Question about Cameras
I can only get my FL-50 flash to go into manual or auto mode, I am wanting to put it into TTL mode but don't know how to do this. I have just changed my E-3 body and wondered if there is a setting I need to have it in in order for the TTL mode to work?
neta
  • 852 Answers
SOURCE: Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Posted on Sep 04, 2005
neta
  • 852 Answers
SOURCE: Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
neta
  • 852 Answers
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
Quack
  • 542 Answers
SOURCE: Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Posted on Sep 08, 2005
advance
  • 107 Answers
SOURCE: wont work
According to the Canon feature chart I have here; the 540EZ Speedlite flash is not compatible with the Digital Rebel XT in ETTL mode. The 480EG is also not compatible. The 550 or any of the others in that product line are would work. David Millier Advance Camera Repair
Posted on Feb 27, 2007
It does not alway fire? I am in the tty mode
check your camera setting....maybe it is set to auto mode
Sep 29, 2010 | Olympus FL-50 TTL Flash
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
Non-syncing Olympus FL-36
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 12, 2008 | Olympus FL-36 TTL Flash
Why is my fl 50 is flashing out of sync ?
Set Shutter at 125 or smaller
Set Aperture at 8
You never told us what camera was flash attached to.
atdlee@netzero.com
Jan 15, 2008 | Olympus FL-50 TTL Flash
Built-in flash and an external flash simultaneously
Yes, please see the following table: Optional Flash Flash Control Mode Capacity FL-50 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The FL-50 flash can be connected with the E-300 camera through flash power grip: FP-1 and flash cable: FL-CB05. FL-40 Auto/ Manual The external flash cannot be used with the built-in flash. * Only Auto and Manual mode can be set in the concurrent use of FL-40 and the built-in flash. (For their specification design, E-300 and FL-40 can not communicate in TTL Auto and R-TTL Auto modes.) FL-36 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The external flash can be used with the built-in flash.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Cameras Logo
18 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
