Question about Minolta Maxxum 400si 35mm SLR Camera
Everytime i used the unit the HELP appear in the
Everytime i'll used the unit the word "HELP"
appear in the menu.
  • 685 Answers
This is a serious internal problem for a repair technician to fix. It will have to got to a repair shop for repair
Posted on Nov 21, 2009
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
I keep getting an error message everytime i turn it on and when i try to look at my pictures in my gallery.. it says something like andriod.proces..media isnt working and also it will knock me off the...
You did a soft reset, try master reset: Here is a step-by-step procedure on how-to perform a factory reset when the unlock pattern code has been forgotten:
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the MID7015******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 27, 2011 | Coby Kyros 716829701508 Tablet PC
How to use adobe editing?
There are a few primary tools inside Photoshop that can be used when you become acquainted with your own cropping and editing computer software. Photoshop can be tough to perfect, particularly if you've not really modified photographs before, yet just like everything, it'll become less complicated when you start to use it and become acquainted with it. You probably should start by utilizing easy, entertaining, simple to use tools, that will help discover the fundamentals ofhow to use Photoshop.
Let us take a peek at a few of the beginner tools which you'll be able to begin to use within Photoshop, so you'll be able to make use of this like a step-by-step guide to operate the below mentioned Photoshop tools and uses.
The Smudge Tool
The smudge tool is really a tool you'll eternally utilize whilst performing simple photograph editing. This makes the particular model's facial area seem softer as well as younger. A couple of good examples would certainly include things like pimples, lines and wrinkles, scarring, skin moles as well as other defects on a person's face. The smudge tool helps make every one of those blemishes disappear.
Warping Tools
It is possible to adjust just how a person appears within a photograph utilizing the warping tool. Possibly an individual within the photo is overweight, and you would like them show up thinner inside the image, and all you will have to make use of is the warping tool. Exactly the same tool is also helpful to make an individual seem taller, so I'm certain a number of your shorter pals would end up being amazed.
Filter Menu
Utilizing the filter menu it is possible to discover numerous great effects you are able to use within your photographs. Most of these diverse effects can easily be located within the filter menu. You may want the picture to appear like an oil painting rather than a photograph. This is quickly accomplished through selecting the oil painting effect in the filter menu inside the artistic sub-menu.
Jul 18, 2011 | Computers & Internet
TOUCH SCREEN IS NOT WORKING
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Oct 24, 2009 | LeapFrog Leapster 2 Learning System
Antifreeze appears to leak everytime I turn on the
it is most likely not antifreeze, but just condensation dripping from the HVAC drain. it is normal and unless it contains orange dex-cool coolant, is not a problem.
Aug 02, 2009 | 2006 Chevrolet Impala
I have a new MacBook White. Everytime I am on Safari for any period of time my computer begins to chime every 10 seconds. I have checked to see if I had anything else open but did not. Any idea what is...
Reset Safari:
Click on Safari in your Safari menu, located at the top of your screen. A drop-down menu will now appear. Choose the option labeled Reset Safari
This will give you the option to delete stored login info, favicons, cache, history, and cookies. If you do a full reset you’ll likely see noticeably improved browser performance, but you’ll need to log in to all the websites that normally “remember” you, so if you doubt you’ll be able to recall all of your login info across the Web, try deleting everything but login info and cookies first to see if that speeds things up.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 09, 2009 | Apple MacBook White- 2.1GHz Intel Core 2...
How do i connect my HBH-600 bluetooth headset to my phone?
hi thanks for using fixya!
Connecting a Bluetooth headset or hands-free speaker unit to your phone involves setting the headset to “discoverable” mode; check the headset manual for how this is done, as it varies by type and model. You’ll also need to find the headset PIN code in its manual – this is usually 0000 or 1234, but again it varies.
Go to Bluetooth menu – from the main menu highlight Settings (Figure 1), click Select, and scroll right to highlight the Connectivity tab. Highlight Bluetooth (Figure 2), click Select and then highlight Handsfree (Figure 3) and click Select.
When prompted to ‘Add a handsfree device’, choose Yes (Figure 4), and your phone will look for all discoverable hands-free units (Figire 5). Select the one that you want from the list that appears and enter the hands-free unit’s PIN code when prompted. The pairing will now be complete.
Once paired, you’ll find the headset listed under the My devices menu in the Bluetooth settings area, from where you can connect and disconnect it.
Hope it will help you. If you need further assistance, let me know!
Regards!
Apr 30, 2009 | Sony Ericsson Akono HBH-600 Consumer...
Shots taken
It is useful for the pro to know the settings automatically at every exposure.But if you dont like you can avoid it by going through the menu.You select "No" to display info or preview
Mar 11, 2008 | Nikon D40x Digital Camera
Re: Smudging
Try Cleaning the printheads. you usually have a utilitie to do this in :- Printer preferences. Also try several Print test Pages. It appears that your getting a surge of ink, at the initial printing stage. use standard paper to do all tests with. 1:- it,s cheaper. 2:- it,ll help soak-up any surplus ink. whereas the glossy paper does,nt soak it up too well. If these solutions don,t help. check HPs site for fault diagnosing and repairing.
Hope this helps you in the right direction.
Mike@Compurepair.
Feb 20, 2008 | HP Deskjet 6980 InkJet Photo Printer
Contrast problem
my monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem?
Jan 25, 2008 | IBM E54 (Pearl, White) 15 in.CRT...
Minolta Maxxum 400si 35mm SLR Camera Logo
51 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
