Question about Canon PIXMA iP90 InkJet Printer
I get color ink tank not installed correctly, but it is and it is new.
  • 235 Answers
If it is installed correctly and it is new, then the problem is in the printer head holding the cartridges, have the head cleaned and try it again and if the same message appears again then a printer head replacement is needed
Posted on Nov 20, 2009
Getting error U043 "The following ink tank cannot be recognized. I have the correct tank. Pixma 520 ...tank # 5 PGBK
The little chips on the front of the cartridge create a trouble for people trying to refill the cartridge, as of right now, there is no way to easily reset the chips. If you refill them, they still register as empty, and therefore don't work.
If the following tips doesn’t help, you can try to install the original new ink cartridge following the instructions in the user manual. This can solve the problem.
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
For information on the compatible ink tanks, refer to the back cover of the Quick Start Guide.
Tips before Replacing Ink Tanks : Important:
- To maintain optimal printing quality, we recommend the use of specified Canon brand ink tanks.
Refilling ink is not recommended.
- Once you remove an ink tank, replace it immediately. Do not leave the machine with ink tanks removed.
- Replace empty tanks with new ones. Inserting partially used ink tanks may cause the nozzles to clog. Furthermore, with such tanks, the machine will not be able to inform you when to replace the tanks properly.
- Once an ink tank has been installed, do not remove it from the machine and leave it out in the open. This will cause the ink tank to dry out, and the machine may not operate properly when it is reinstalled. To maintain optimal printing quality, use an ink tank within six months of first use.
- Color ink may be consumed even when printing a black-and-white document or when black-and-white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the machine's performance. When an ink tank is out of ink, replace it immediately with a new one.
After replacing ink tank;
Turn off the machine, and unplug the power cord of the machine from the power supply. After five minutes or more, plug the power cord of the machine back in, and then turn on the machine.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 25, 2010 | Canon PIXMA MP520 InkJet Printer
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Color tank isn't installed --- but it is!
Make sure that all tickers are off from the tank and clean the housing good and run self clean first and reset the printer
Nov 07, 2009 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Ink tank confusion
Sometimes the new ink are faulty. If replacing it has solved the problem take it back to the shop for a refund.
Oct 21, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
PIXMA IP1500 - CANON PRINTER
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
WILL NOT PRINT!!!
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. (See the illustration below this paragraph for ink tanks recommended for this model.) If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head. sj402022.jpg
Ink Tanks:
- BCI-24 Color
- BCI-24 Black
  1. Make sure the power is turned on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover.
  5. Check if the ink tanks are installed properly.
  6. When installing the ink tanks, push the top of the ink tank until a click sound is made.
  7. Close the Inner Cover.
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. Return the Scan Unit to its original position. The LCD displays a message asking if you replaced an ink tank.
  9. Press [+] to select [NO] and exit.
Jan 09, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA iP90 InkJet Printer Logo
118 people viewed this question
old marine
old marine
