Question about Garden
Dont know how to change from blower to vac
How can I change from vacuum mode to blower mode?
Don't know what make you have. Maybe post a picture if you're still struggling. Most electric vac/blowers have a leaver or a dial/knob on the side that you turn in order to go from vac to blower, but mort the time you also have to put extra pipework on too as the blower outlet then becomes the vac inlet.
Apr 16, 2016 | Garden
My leaf blower doesn't start, I put new gas in it & put new sparkplg but doesn't start. Please help me
you list it as an electric vac if it s gas ans you have changed gas and plug if its older you gase lines could be brittle I had to change them on mine to get it to work
Sep 17, 2010 | Craftsman 225 Mph Electric Blower Vac
How do we activate blowing system on the blower/vacuum? I don't know how to switch from vacuum to blower?
1) the pick-up tube for vacuum is removed
2) the vac bag is removed and blower nozzle is installed in it's place
Oct 30, 2009 | Craftsman 4 Cycle Blower/Vac
Troy-bilt gas blower/vac stopped and pull cord won't come out
NOPE You can buy new cheaper than have this one repaired, Also I don't recommend using these for a vac on leaves. Leaves are very very dirty and these blower vacs usually dont last long when used as a vac. The seize problem was from an improper fuel mix. THE next one you getone use a little more oil, than says in the owners manual. Like if it says 50/1<<>> mix 40/1 more oil will just foul the plug and oil the muffler,but you will not have a seizure problem. I have never had a problem with a 40/1 mix .
Oct 21, 2009 | Troy Bilt 31cc Quickshift Blowervac, Model...
Weak spark
check the gap between flywheel and coil should be 010.gap.allso check magnet on flywheel.let me know what you find out.o if spark still weak change coil.let me know.ok
Jul 23, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Fuel lines dry and brittle how to replace on craftman 24cc gas powered blower vac
take one of the lines to a hardware store and see if they have the proper size. You should be able to change them easily. Just remember to clamp the ends to prevent gas from leaking out.
Jun 15, 2009 | Toro Blowers Rake and Vac - Electric...
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
Craftsman 4 cycle leaf blower/vac #71-79731
Solution offered by MrFixIt Jerr solved my problem. Thanks for the help. This is a great service. Mr. G.
Feb 08, 2009 | Craftsman 4 Cycle Blower/Vac
#51574 Toro Rake&Vac--Lost manual
You should have another door that goes in front of the impeller (blade) which doesn't have a vacuum attachment. You should first detach the vacuum door from the bottom, put on the blower tube, and install the other door that came with the blower. Hope that helps.
Nov 30, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
