Question about Fuji FinePix J12 Digital Camera
I have a fuji finepix J12 camera. It has been
I have a fuji finepix J12 camera. It has hardly been used. The charger is no longer charging the battery. The light doesnt come on any more. Does this mean I need a new charger?
Benimur
  • 6966 Answers
SOURCE: Memory full
As you posted, both cameras have their memory full then you need to free up the internal memory either by deleting the contents or transferring them (the pictures) to your computer.
To transfer to your PC, you would need the installer/driver CD that came with the cam as well as a USB cable. You need to run/install FinePix Viewer prior to the USB connection. Follow on screen instructions. When asked to connect the cam do so. All others are explained with illustrations on the User's Manual. A copy od the A700 User's Manual is available here.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 14, 2007
SOURCE: Fuji Fine Pix Z5 battery won't charge
My sister's Z5 was having the same problem. I realized she had the battery in upside down. There are no guides on the battery to insure that it goes in the right way.
If the battery is in correctly, and it is still not charging, I would call Fuji to get it repaired.
Posted on Apr 12, 2008
Steve5
  • 423 Answers
SOURCE: Can I charge the battery in Fuji FinePix J10 with my PC?
Nope. Gotta use the supplied external charger. Won't charge via USB, if that's what you are hoping.
Posted on Jul 04, 2009
  • 24 Answers
SOURCE: Digital camera not working
Battery must be ok. Check the switch contacts. Battery contacts.
Posted on Sep 11, 2009
sardanadixit
  • 813 Answers
SOURCE: what does write error mean in my fuji finepix A340
When does this error message come? Does it come while clicking the pictures? Try replacing the memory card of your camera and then check, as usually it is a memory card related problem.
Please rate this solution in case it works for you, it helps us in assisting users like you. In case the problem is still not resolved, do not rate thesolution, leave a comment instead and we shall assist you further.
Posted on Nov 11, 2009
My fuji finepix A900 is not charging with usb cable on my computer
The A900 is not a battery charger. It uses two standard AA batteries, either disposables or rechargeables. If you choose to use rechargeables, they must be charged outside the camera, using a separate charger.
Sep 22, 2011 | Fuji FinePix A900 Digital Camera
I have a fuji finepix j12, i have uploaded pictures onto my computer before, but they are not uploading now. a display window pops up for a second, disappears and then the load icon goes...
Try NOT connecting your camera to your computer?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 15, 2011 | Fuji FinePix J12 Digital Camera
How can i transfer my photo from my fuji j12 to my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Jul 19, 2010 | Fuji FinePix J12 Digital Camera
Can I use a finepix j12 as a webcam?
Sorry you can not...
Hope this has helped you... Thanks...
Feb 27, 2010 | Fuji FinePix J12 Digital Camera
How can i transfer pix off my fuji j12 to my computer using the usb cord
Forget the cord. Use a card reader to download your pictures to a folder you create on your desktop.
Oct 08, 2009 | Fuji FinePix J12 Digital Camera
Can you charge the camera through the computer via the USB lead
Short answer: No.
You need to put the battery in the charger to charge it.
Oct 06, 2009 | Fuji FinePix J12 Digital Camera
Lens will not retract
As bad as I hated to, I purchased a new camera for $109.00 vs. $90.00 for the repair. I still intend to look around for a similar camera,maybe on eBay or at a yard sale for parts. I think that I would like to give the repair a whorl. I can't tear it up any worse ... it does not work now!
Thank you for allowing me to post ...
R
Jun 19, 2009 | Fuji FinePix J12 Digital Camera
Finepix j12 flash isn't working
Check menu to be sure flash is "on" - Fuji is located in Edison, NJ. You may contact them or a local authorized service center. There are two in Florida, but not sure where you are.
Southern Photo is the name
Apr 15, 2009 | Fuji FinePix J12 Digital Camera
Got no more driver cd finepix j12
If you plug the camera in, go to My Computer and open the camera from there.  That should allow you to copy the files or pictures from the camera right to your computer.  You can also get the drivers you need from Fuji's website.
Mar 29, 2009 | Fuji FinePix J12 Digital Camera
Fuji FinePix J12 Digital Camera Logo
55 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
