Question about Whirlpool Refrigerators
The post between the doors of my side by side refrigerator is hot. If you open the doors and put your hand on the outside,it is hot. I cleaned the bottom of the frig last nite and noticed the cooling fan wasn't running. I touched the fan blade and it started to run. Do I need a motor? Common problem??? Its a whirlpool gold model # GS6SHAXMS00
  • John Manetti Nov 20, 2009
    Is this the only thing it could be? If the fan was working properly..what else could cause this?
  • Whirlpool Master
  • 1,606 Answers
The fan motor needs to be replaced . Pt # W10124096 , is the part number for the condenser fan motor ( compressor cooling fan ) . It costs about $ 100.00 for the part , but is easily replaceable ( 2 or 3 screws ) .
Posted on Nov 20, 2009
  • Mike Smith
    Mike Smith Nov 21, 2009
    Either dirty coils at the front , down behind the kick plate , or , compressor cooling fan not working , are the only things which can causes the center strip to get extremely hot . If air cannot be pulled over the coils , to remove heat , then the compressor will get hot also , and possibly damage the compressor . Air not flowing over the coils , causes the coils to get extremely hot , and a portion of the coils , run just behind that center strip . That part of the coils , is called the yoder loop .
Buttons don't work to open rear passenger door
You need to be more clearer with your question...not sure what you mean by "hand wire comes outside van"??? also not sure what you mean by "get buttons to open door" are you talking about the sliding side doors on your 2006 Montana.if so clean off the contacts they are located on the door post also on the door itself..hope this helps
Sep 29, 2014 | 2006 Pontiac Montana SV6
Door hot
Totally normal. The condenser sends hot gas through the frame to stop the freezer door freezing to the frame. Check to see if you have a fan behind the condenser grill and make sure its running and clean
May 04, 2017 | Maytag MSD2756G Side by Side Refrigerator
The top of my avanti mini refrigerator is hot
The return section of the gas cooling circuit is hot. Goes out cold comes back hot, so if that area has return lines behind it nothing wrong with the outside of a fridge being hot. Some fridges even have heaters built in around the doors and openings to prevent freezing up.
Jul 10, 2013 | Avanti 322Y Compact Refrigerator
Post between freezer and refrigerator doors is hot
I have seen a programme on TV which showed a cable between the doors which over time with constant opening and closing became worn. I should contact the manufacturer.
Apr 21, 2012 | Samsung RS2630SH Side by Side Refrigerator
When you touch the box when the doors are open it is very hot on the outside of the box frame.
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jul 17, 2011 | Bosch B22CS80SNS (220 cu ft) Side by Side...
The strip between the doors is VERY hot cant keep hand on it..i was told it had a hot gas bypass..what can i do ??
heatman101
Jul 02, 2011 | Whirlpool ED2FHEXN Side by Side...
The outside middle front & left hand side of the fridge were hot
The reason you feel heat by the middle of the door is because of the "mullion heater' or anti-sweat.
Check the temperature of the freezer, must be below 12*F for the ice maker to work.
Apr 23, 2009 | Kenmore Refrigerators
Freezer side is hot outside
There is no problem at all. The outside of the freezer is hot because it is rejecting heat from the inside of freezer compartment to the outside surroundings, this is a normal refrigeration cycle. As for the seals being hot, this may be to prevent the door from freezing shut. i know that commercial and industrial freezers have heated seals for this reason.
Nov 13, 2008 | Maytag MSD2756G Side by Side Refrigerator
Ge side by side freezer refrigerator
That is called a heat strip. Used to keep moisture down around the door gaskets. You will need to roll unit out, take lower back plate off and check to see that the condinser fan is turning when compressor is on. If not,replace fan motor
Jul 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Front between doors is VERY HOT
Had the same problem. I opened the "meat" lever controlling the "hole" between the freezer and fridge compartments (mine is next to the crisper trays at bottom) and put my finger in it to clear any blockage. It's been 24 hours and the center post is no longer hot. Think maybe I had a blockage or the hole was closed off and whatever is in that middle wall needs the cold air flow for cooling. If you discover some other remedy, please let me know.
Dec 29, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
108 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
