Question about Creative Labs ZEN V Plus MP3 Player
Downloading problem bought pink floyd oh by the way boxset, ripped to wmp library, works perfectly but when downloaded to zenvplus will not play saying "playback error". any ideas?
Reset it or when downloading, turn off and try again.
Posted on Jan 19, 2008
6ya staff
SOURCE:
Losing ripped CD's And downloads from Windows Media Player
When you rip using WMP the music files are saved in a default location.
  • Open tools
  • Open Rip
  • Read "Rip Music to This Location"
  • If no artist on CD the folder will be "Unknown Artist"
  • In that folder contains by date-...the folders containing your music
You can check before you close WMP that they are saved
Nov 22, 2015 | Computers & Internet
How to play DVD RIP file on windows media player on Windows 7 64 bit os
download and install win7 codec pack (free) .
then you will be able to play
Jan 01, 2011 | Microsoft Windows 7 Home Premium Full...
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
May 01, 2010 | Coby MP-C653 MP3 Player
Downloading of CD's to MP3 Player
Are you trying to synch tracks directly from a CD. If you are, you first have to rip the tracks. In windows Media player, you first need to setup the type of file you want to rip to (MP3 in this case). Right click on the top bar of the WMP and select Tools|Options. Select the Rip tab and under the rip settings, change the format to MP3. Select the quality you want (higher quality means less music can be stored on your unit). 192 kbps is a good setting. Now, click OK or apply as appropriate to get out of the menu. Insert your CD and click on the RIP tab of WMP. Your CD's tracks should automatically come up with checks marks beside them. Start the RIP process. Once it is complete, you can then drag the newly ripped files from your library to the Walkman and they should be synched.
Feb 18, 2010 | Sony Walkman NWZ-S616F MP3 Player
Ripped songs from CD, E-Matic MP3 player won't play them,
you can download bit torrent, open mininova.com and download it from there.
Jul 28, 2009 | Nextar MA933A MP3 Player
Downloaded books from the library won't play
I was having the same problem when I used Overdrive Media Console to transfer my audiobook files to my Sansa. I updated the license and retransferred and even tried changing the USB settings on the mp2 player. What finally worked? Using Windows Media Player to sync the files instead. When I hooked up my Sansa I chose "use WMP to sync files" and then I dragged/dropped the audiobook files to the mediaplayer window. The audiobook now plays without any problems since WMP made sure the files have the latest subscription update code.
Jun 01, 2009 | SanDisk Sansa e260 MP3 Player
How doi get the files to go to my windos media player library?
GO TO THE FILE WERE YOUR E-MUSIC IS DOWN LOADED TO AND EACH SONG AND LAUNCH IT FROM THERE MAKE SURE YOUR WINDOWS MEDIA PLAYER IS SET AS YOUR DEFAULT PLAYER YOU CAN DO THAT BY RIGHT CLICKING ON EACH SONG AND CHECKING IT AFTER YOU LAUNCH THE SONG FROM THERE IT SHOULD PUT THAT SONG IN YOUR WMP LIBRARY AND ALSO USE WMP TO PLAY THE SONG YOU DONT HAVE TO PLAY THE FULL SONG JUST THE BEGINING OF IT,IF THAT DOES'NT WORK THEN CHECK YOUR WMP SETTING TO MAKE SURE THAT THE SONGS THAT YOU LAUNCH WITH WMP ARE AUTO ADDED TO YOUR LIBRARY
Mar 14, 2009 | Audio Players & Recorders
Sansa synch problem
Change the Rip settings in Windows Media Player to convert the CD to mp3 format and then re-synch it - it will work. WMP probably synched it as a raw CDA, which the Sansa cannot recognize.
-Tha Mp3 Doctor
Oct 18, 2008 | SanDisk Sansa Clip MP3 Player
Windows media player not working
Very the file you are trying to play is still there , if it is then create a new play list by allowing WMP to scan your system for playable media. If this fails or the above aint the latter then i'd suggest you uninstall WMP and reinstall it. WMP is in the control panel / add or remove components / Windows Components. You can also log in to microsoft web site and download the latese WMP and install it .
Jul 09, 2008 | Microsoft Windows XP Home Edition
Transfer music from ipod to m250
I'm assuming your iPod music is in iTunes. You can point Windows Media Player to the folder on your PC that iTunes stores music in. For those songs that are ripped from your CD collection, they will appear in WMP to be synced to your Sansa. That's the easy part.
Unfortunately, your music that you purchased from the iTunes store will not. There may be an easier way to do this, but this method will work. First, burn your iTunes purchased songs to a CD, then rip them back to your PC. Set WMP to also look in the folder that you rip to for music in addition to your iTunes folder. You can identify several in WMP so once you establish the library, you won't have to switch back and forth between your iTunes library and this new library. You will then see that music in WMP to be synced as well.
Again, unfortunately, the songs from the ripped library will not have the song, artist, year, genre, etc., but you can edit this information easily. Right click on each song that doesn't have good info, and choose the "Advanced Tag Editor" option from the menu. There are several tabs that will appear in the window, and you can put in as much or as little info as you'd like. You can use your iTunes library to get this information from.
It is a bit of a tedious process, but it works!
Good luck.
Jan 14, 2008 | SanDisk Sansa m250 MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
61 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
