Question about Delta Machinery Unisaw 3 Hp Left Tilt Table Saw with Unifence
When I push the start button, the motor starts,
When I push the start button on my deta unisaw, the motor starts, but the moment I take my finger off the start button, the motor stops again.
  • ljudh Nov 21, 2009
    The Start/Stop switch in the front is wired to some kind of relay box in the back of the saw. When you hit the start button, the signal goes back to this box. The power from the wall socket feeds into this box. The line that goes to the motor passes through this box. There are relays in the box but also a transformer and what looks like a switch of some kind and then another unit. So it doesn't look simple to me. Any one of these pieces might be defective or the wiring done wrong. The machine was somewhere else for awhile and I've heard that they may have wired the Start/Stop differently perhaps because it didn't work. But I am not sure.
  • 1,498 Answers
The symptoms you are describing indicate an overload state. According to page 14 of the operations manual, the proper course of action is to wait 3-5 minutes and try again.
If it continues, to contact a qualified electrician.
Doesn't really give a lot of help though, does it. Prior to such measures, I'd check on the following:
  • The cord is in good shape. No frays.
  • Is the power cord warm?
  • Is there an extension cord involved?
  • Is this a recent development after a recent event?
  • Does the action on the switch feel any different?
  • Is there anything else on the same circuit that could cause a low voltage situation?
My gut feeling is the switch is no longer locking and needs to be replaced.
If the unit is still covered by warranty, exchange it. If not, the web site in the Link above is also the source for parts.
I cannot be more specific without your exact model number.
Best regards
Mike
Posted on Nov 21, 2009
  • Justin Case
    Justin Case Nov 22, 2009
    So it used to work.
    It was loaned out
    When returned it had these symptoms.
    Ok, I need to look something up. In the meantime, some questions.
    • How comfortable would you be working with electricity?
    • Can You identify a relay? Its configuration?
    • Can You identify the coils and poles of a relay?
    If you feel up to it, one way or another we will get this going
    Mike
  • Justin Case
    With a relay in the picture here is the normal startup sequence:
    1. Press the Start button
    2. Relay is Energized
    3. Normally Open contacts on relay are Closed
    4. One set of contacts powers the motor
    5. Another set of contacts continues to power the relay after the Start button is released
    The power to the relay is not getting there. The problem could be a wire that came loose (unlikely) or the Stop Switch
    The Stop Button is a Normally Closed Switch that the power for the relay runs through. When pressed, the relay loses power and reverts back to it's 'Normal' state, contacts open, the motor stops.
    If the Stop Button was pressed and didn't pop all the way back out, that would perfectly mimic the symptoms being presented.
    To check this, you need a meter:
    • PULL THE PLUG, DISCONNECT THE SAW FROM THE WALL POWER
    • set the meter to measure Ohms or continuity.
    • Put the leads on the two contacts of the stop switch
    • The reading should be zero resistance or a beep
    • Pressing the stop button should read infinite resistance.
    • Anything else the switch is faulty, the cause of your problem and needs replacement
    Mike
  • 770 Answers
It sounds like a bad switch. The circuitry on that saw is not that complicated and I believe the switch is held in by 2 screws and will lift right out. You can probably test it at radio shack and if you don't want to order an OEM replacement and don't mind an aftermarket looking switch, radio shack can sell you one that will work. Good Luck. I hope this is helpful!
Posted on Nov 20, 2009
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Delta 10 inch unisaw switch hums wont start motor
All of the above are correct. However, before you go nuts with motor stuff, unplug the saw and make sure the blade shaft turns freely, If it doesn't, look for something jammed in the belt and pulley mechanisms. Loosen the drive belt and check the motor shaft rotation and the blade shaft rotation separately. If you find nothing, remove the belt and try starting the motor. If it won't start like this (no load) there is a motor problem. If it does start, find the drive mechanism problem and fix it; not many possibilities. Good luck.
Sep 23, 2012 | Delta X5 3Hp Left Titl Unisaw with...
My dryer will only run for 5-10 minutes
sounds like you have a bad motor,when it heats up it's stalling and when you go to restart it there are start windings and run windings in the motor it's not switching over to the run windings so when you hold the start switch in you're sending constant power to the motor,all it does is when you push the button it's a momentary switch power goes to the motor and hits the start winding in the motor should be just for a moment,then it switches over to the run winding and this keeps the motor running,your motor isn't doing this,
Dec 23, 2017 | Whirlpool Dryers
Delta x5 unisaw 3 hp. couple days ago it was running strong never had a problem before. push start motor tries hard to spin but nothing besides a hot motor barely touch it hot. 10 min later saw starts...
The motor has a component called a clixon (there are other names for it, too). The clixon has a step up coil and a capacitor that gives the motor an extra bit of juice to get started turning. When it fails, you get the kind of thing you're talking about. If you keep trying to use it without this component working, it overheats the windings and shorts the motor out, killing it. You're most likely going to end up replacing the motor now.
Sorry I didn't have better news for you.
Jul 09, 2011 | Delta X5 3Hp Left Titl Unisaw with...
Delta Unisaw 34-782 Starts with a "Bang"
The capacitor is probably failing. Take the motor to an electrical service center (most mid-to-large cities have them ... usually something like "Industrial Electric and Motor Service" ... and ask to have it checked. Caps are cheap!
Nov 02, 2017 | Delta X5 3Hp Left Titl Unisaw with...
Dryer will not start when I push the start button. You can hear the sound of the dryer wanting to turn on but it does not. I have already tried to unplug and replug.
If the motor is trying to start only when you have your finger on the start button but won't continue to run, the run coils in the motor might be bad. If it just buzzes (hums) when you try to start it, the start/run switch in the motor might be bad, or the starter windings might have an open. Either way, it sounds like the motor might need servicing.
Jan 02, 2010 | GE Spacemaker Washer and Dryer Electric...
I pushed the start button on the dryer it turned on but didnot st
The instant you press the button on the console, the motor should start. When it starts a mechanism in the motor operates a switch mounted on the motor (provided w/new motor). That makes a circuit which replaces the action of your finger holding the button by creating a bypass circuit. This bypass circuit takes the start switch completely out of the circuit and keeps the motor running.
Your motor is not making this bypass circuit and needs to be replaced.
Oct 28, 2009 | Kenmore Dryers
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Hoover tumble dryer
I think you may have a bad relay on the motor, where power is re-applied after the push start is released
Oct 11, 2007 | Hoover HDC6 Electric Dryer
Delta Machinery Unisaw 3 Hp Left Tilt Table Saw with Unifence Logo
61 people viewed this question
Top Delta Machinery Saws Experts
Tom Chichester
ray gallant
Are you a Delta Machinery Saw Expert? Answer questions, earn points and help others
