Question about Canon LASER SHOT LBP-5200 Printer
NETWORK BOARD ERROR BUT PRINT WITH ANOTHER PC CONNECTION
  • 23 Answers
I recently got the LBP 6300dn Laser and had similar issues. I initially had 1 router which was wireless and a switch to connect a wired pc and the printer in another location, both via Ethernet. was having major problems as when the printer went idle it would not show up as connected. so got rid of the switch and connected laser printer to the router. same problem.
After lots of trial an error I think I have found a FIX!!!
go into devices and printers then right click the printer to get printer properties. go to the ports tab and click on configure port. Then disable "SNMP status enabled" at the bottom and thats it! been running my laser printer now only connected via Ethernet for a few hours now and no disconnection!
Posted on Feb 26, 2011
How do I fix error cf 248 for my Kyocera 1128. I have tried several times shutting off. Taking out toner and checking paper jam
If its what I think it is, then the error occurs when your machine is receiving a corrupted print job. This is shown by the data light flashing for several minutes before showing the error.
If this is the case, then unplug the network cable from the machine, power the machine off & on & wait until it comes ready. If the machine comes ready then try a photocopy. If that works then it is a corrupt print job. Before plugging the network cable back in, check any PC's that print to the copier & check the print queues to see if any PC's are still spooling a print job. If so, delete the print job & re-connect the network cable & test the machine.
I have found most corrupt print jobs will be from the internet & will have "www......" listed as the print directory list.
Hope this helps.
Dave.
Feb 13, 2016 | Kyocera Office Equipment & Supplies
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Aug 14, 2008 | Lexmark Office Equipment & Supplies
79 error
79:xx Error- general firmware error- look at this fault the same way you look at windows blue screen of death - theres usually noting wrong apart from corrupt data in a print job- disconnect the printer from all network sources cycle the power with no network connection to clear fault then clear all print queues from the workstation (PC) before reconnecting network. also you might want to try a config page print test before reconnecting network..
if unfortunately the printer will not come to ready when the network has been removed, then the formatter is likely to be the cause .
Jan 27, 2014 | HP Laserjet Cp2025n Printer
Error code 40.0
A connection with the card in EIO
slot X has been abnormally broken.
1. Press to resume printing.
NOTE
A loss of data will occur.
2. Check that all cables are
connected to the EIO ports
and that the EIO board is
seated properly.
3. If possible, print to another
network printer to verify the
network is working properly
Jul 24, 2012 | HP Color LaserJet 5550 Printer
900 service rip software
The 900 error usually indicates a software or communications problem. If the 900 error occurs only when the printer is receiving information from a network or computer, you should contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer.
To check the base printer
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer
May 05, 2011 | Lexmark Optra T610 Laser Printer
What does 900 Service RIP Software error message mean and how do i reslove it
If the 900 error occurs only when the printer is receiving information from a network or computer, contact your software/network support. If the error occurs when the printer is idle or not connected to the network or PC, there may be a printer hardware or connection problem. Sometimes a bad connection with an Internal Network Adapter/Network Card can cause the problem. The first thing to check is the base printer. To check the base printer:
  1. Turn off the printer and disconnect every cable, except for the power cord.
  2. Turn on the printer and see if the error returns.
  3. If the error does not return, try to print a test page from the Test Menu.
    1. Press Menu > to enter Menus.
      Optra S series and Optra K series printers: Continue to press Menu > until you see TESTS MENU.
      Optra T and Lexmark T and W series printers: Continue to press Menu > until you see UTILITIES MENU.
    2. Press Select to view the menu items. TESTS/UTILITIES MENU is now on the first line of the display.
    3. Press the Menu > button until Print Menus appears on the second line.
    4. Press Select.
    5. If the display tells you to change paper, press Select or the GO button to print.
  4. If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  5. If the 900 error occurs again before, during, or after the printing of the test page, remove all options (internal network adapters, optional feeders, second drawer options, finisher options, additional memory, etc.) from the printer.
  6. Then turn on the printer and try to print the test page. If it still posts the 900 error, the printer may need to be serviced.
  7. If the error does not return, then the problem may be with one of the options.
IMPORTANT: If you receive an Invalid Engine Code error message when you power the printer back on, there is a problem with the printer. An Invalid Engine Code condition will cause a 900 RIP Software Error message to appear if you try to use the printer. The Invalid Engine Code error means either that your printer has lost its stored operating code for the engine board or that the printer's engine board has gone out.
Aug 02, 2010 | Lexmark Optra T610 Laser Printer
Error:SSG_THNK-32 Diag/Eerr(9)
create new user and your problem is solved
descomp_7@yahoo.com
Jun 24, 2009 | Office Equipment & Supplies
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
Canon LASER SHOT LBP-5200 Printer Logo
1,684 people viewed this question
old marine
old marine
