Question about Amana ALW880WH Top Load Washer
Washer wont agitate with med - large loads
My washer has gradually stopped agitating havier loads. I am now down to the smallest load it will wash. All the other cycles seem to work fine, it just wont agitate after filling. Any help would be appreciated. Thanks
  • xanji Jan 12, 2008
    I took apart the washer today to have a look and found black powder under the motor. Any ideas?
    Scholar:
  • 57 Answers
Without knowing the age of your machine, your agitator "dogs" may be wearing or worn out. It should be fairly easy to check them out. You will need to figure out how to remove the agitator Usually the agitator will have a fabric softener dispenser or a cap on the top. Pull the dispenser/cap off the top of the agitator and you may see a screw holding the agitator in place. Once you lift the agitator out, the "dogs" should be visible. Most appliance stores should carry the dogs for your particular washing machine. I've added a couple of photos so you have an idea what to look for.
Black powder under the motor??? The motor uses carbon "brushes" to electrically make the motor move. Without going into motor theory, I would tell you that the black powder, in a small amount, is normal. The brushes can be replaced, and again, can be found at most major appliance dealers
Posted on Feb 23, 2008
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
Maytag Performa Model# PAV 2300 AWW agitator & larger wash load
pull the agit out and look at the side just below the slots there is a small hole there and the lock screw is probably missing . / to pull agit you turn the screw out and to lock it down you turn it in till it stops . if no lock screw the out comes the agit ... could be very bad in spin if it came out . i have heard of this .. so lock it down .. **** hope this helps .
Dec 07, 2009 | Dryers
Won't stop filling, water just keeps running into washer even after agitation starts have to turn water connection off to stop filling
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
Aug 26, 2009 | Washing Machines
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Does not agitate with large load
have same problem but mine take large and small loads and leaks
you need part #ap4253876 made by whirlpool
Feb 28, 2009 | Amana ALW480DA Top Load Washer
Model20882990 WASHER PROBLEM
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 01, 2009 | Kenmore 20172 Top Load Washer
Kenmore washer machine series 80
If it will not spin either, you most likely have a broken drive coupler. This machine is "direct drive" and has no belt. As techs, we see this several times during our work week. Otherwise, if you have the "two piece" agitator, you may simply need new "dogs" in the agitator. if the machine spins fine, fill it only on the smallest load size with no clothes in it. When the agitate cycle starts, take note if the bottom section of the agitator is going back and forth. If it is, and the upper part does not "ratchet" then you just need to rebuild the agitator and that is an easy job.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Same problem
ck lid switch blocked pump would not prevent spin unless it was locked up then probably wouldn't agitate either
Jul 20, 2008 | Kenmore 22422 Top Load Washer
Amana ALW880WH Top Load Washer Logo
253 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
