Question about Lexmark X2690 All-In-One InkJet Printer
How can i force it to print color jobs in black and white only
  • 3,600 Answers
Open the printer software and click on properties clcik on print black and whit only then save and close and yo should be set to go.
Posted on Nov 20, 2009
Why do print jobs print out normal, faded, or color (for an all black job) randomly?
I would suggest using the printers self head cleaning as it sounds like the heads need cleaning
Mar 03, 2016 | HP LaserJet CP3505dn Printer
My Ricoh SP 232sf wont print at all because the K toner is out of toner but it has plenty of color. Can I force it to print somehow?
Unfortunately, no, the printer won't print even in color if the black toner is empty. The black drum rotates whether the copier is printing in black & white or color, so if black is empty you can't print at all.
Feb 23, 2011 | Ricoh Aficio SPC232SF All-In-One Laser...
My canon pixma mp620 won't print black ink but other colors print ok.
Does printer have 2 black cartridges, 1 large 1 small? if so, the small black one and colors only takes care of the color print jobs and the large black one, the main black and white jobs. Make sure you don't have an empty large black cartridge.
Aug 15, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Printer A10922 will only print in black. Color cartridge renewed 1 year ago and has been working well.
  1. Check that your color cartridge/toner is not empty or blocked.
    This is the least likely cause of the problem, but an important check to make. Most color printer drivers and/or software provide functions to verify alignment and color output. Consult your manual or open your printer driver by clicking Start : Settings : Printers and right-click on your printer's icon and select Properties. 'Browse' the Properties dialog for options that perform system checks.
  2. Look for a 'Print only Black and White' option.
    Open your printer driver's Properties dialog (see above) and look for a color option that uses black only. Uncheck it or select an option that enables color. Some color printers have different resolutions for color and black-and-white (usually higher resolution in black-and-white). Some applications (not Origin) will force a printer to use a quality mode that affects this option, and if the resolution is forced to its highest the color output may be disabled.
  3. Enable gray scale printing.
    Some combinations of printers and operating system versions can lead to a miscommunication between Origin and a printer driver. Under these circumstances, Origin may 'think' it is dealing with a black-and-white printer when it is actually using a color printer. Beginning with 6.1, the Origin Print dialog displayed one of two messages depending on the print capabilities read by Origin:
    1. Enable color as gray scale
      This check box displays for color printers
    2. Use simplified colors
      This check box displays for black-and-white printers
    If you are seeing the first checkbox and you are using a color printer, then checking the box should tell Origin to send all color information and let the printer handle any conversions that may come up. In earlier versions of Origin there was a rather cryptic "Print color on black and white printers" checkbox which did the same thing.
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
HP5600
You would need to go to your control panel, then printers, then right click on the HP5610 and then properties. Once there, you would need to look for the color setup screen. You should be able to choose something similar to: "print colors in black & white only". That is the only thing you can possibly change to force black & white printing. However, not every printer has this feature.
Jun 20, 2008 | HP Officejet 5610 All-In-One InkJet...
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Messege: Yellow Cartige is low
You can specify that a print job prints in black and white in the properties screen when you print something. You may even be able to save it as a default in the printer driver default printing settings. Unfortunately I've never seen a colour laser be able to ignore it's color cartridges before, you may be forced to replace that empty cartridge.
Oct 25, 2007 | Lexmark C510 Laser Printer
Open Questions:
See all Lexmark X2690 All-In-One InkJet Printer Questions
Lexmark X2690 All-In-One InkJet Printer Logo
114 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
