Question about Sony Ericsson Satio Cell Phone
My only problem that I can find at the moment is that whenever someone calls me, I cannot hear anything they are saying. Apparently they can hear me and when I turn it on speaker phone I can hear them. Also when I plug my headphones in, I can hear them. So I was just wondering if the problem is something that I can fix... Thanks
I can't hear My Calls
The problem with your phone is that the earpiece on your phone is bad that is why you cannot hear the party calling you or hear anything while you call.
All you need to do is to replace the earpiece on your phone and you will see that you can hear whoever you are talking to on your phone.
Change the earpiece on your phone and you will see that the problem is solved. meanwhile, you can keep using the headset pending the time you will replace the earpiece.
Take care.
Jun 28, 2010 | Palm Pixi Cell Phone
Speaker is muted
I had the same deal. But I was able to solve the issue. Go to your setting and tools and go to phone setting and check your TTY modes make sure that your phone is check under TTY-Hearing if not that's your problem ..make sure you check it and save it than turn off your phone and wait 5 minutes than turn it back on.. and you should be set. Ready to use
May 22, 2010 | LG VOYAGER VX10000 Cellular Phone
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
I can't hear anything when I call
I had this problem. It appears that the solder joints on the headset jack are rather weak. When they break, the phone thinks there is a headset inserted into the jack, even when there is not. This disables the phone's built in speaker and mic. The solution in my case was to either replace the phone or have it fixed under warranty/insurance.
Apr 12, 2009 | Palm Treo 755p Smartphone
Can't use earpiece...? (Motorola Razr)
Have you raised the volume while you are on a call as this is the only way the ear piece volume increases.
If this doesn't work then I'm affraid you have a faulty earpiece
Nov 06, 2007 | Motorola Mobility RAZR V3
Problem with Audio on Handset
that mean you handset speaker have problem change the speaker or buy new phone for more happy moment
Sep 13, 2007 | Nokia 6133 Cellular Phone
Its calling but i cant hear anything
Earpiece gone. wen u try 2 ring out put it on loud speaker if it works on loud speaker then ur earpiece has gone
Jan 04, 2007 | Motorola Mobility RAZR V3
"Car Kit"
this model do that when it get wet if that the case there is nothing to do but chage the board, go to the celu store they have jonk to fix these for about $25.00 more or less..good luck
Aug 06, 2006 | LG VX6000
Sony Ericsson Satio Cell Phone Logo
148 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
