Question about Indesit W 123 Front Load Washer
The dryer on our Indesit WD 12x has stopped working, any ideas please?
  • Indesit Master
  • 3,463 Answers
More than likely heater and or thermostat/s problem.
These are located in the top of the washer.
Remove top cover, and you will see a long aluminium box, this is the heater manifold, and the element is inside here, the thermostats are on the top, you will need a meter to test them.
Please rate my solution.
Thanks.
Posted on Nov 21, 2009
How to take out water pump
There are two ways of fixing drain pump depending on serial number of appliance. One easy mounting with three screws and the other is using the anchor tab where you should turn the drain pump counter clockwise and remove.
25602824-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Also, follow this link:
http://www.espares.co.uk/advice/0/2308/indesit-washing-machine-pump-replacement-and-f11-error-
Dado
Mar 23, 2015 | Indesit Washing Machines
My WD 12X machine is not drying the clothes. They get hot but not dry. Is there a filter somewhere that needs to be cleaned?
Presuming that this is an Indesit WD12X.
Yes, there is a filter at the bottom left of the machine (It can be clearly seen in the illistration on Page 14 of the manual, figure 6).
If you don't have a manual, you can download a PDF of it here:
http://www.indesit.co.uk/indesit/_pdf/manuals/19503326500_UK-USA-AUS.pdf
It's highly likely that the water isn't getting evacuated because the filter is blocked and so there is just too much water to dry. Unscrew the filter, clean and replace. I'm amazed to discover that (so far as I can see) The manual never even mentions the filter! Well done Indesit
Jul 19, 2011 | Washing Machines
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Indesit 1570c - it heats but the drum does not turn...
You probably have a broken belt. You have to remove the shell and reroute the belt. You can do it yourself for bout 20 bucks...Good luck. Look in your manual for proper routing of the belt. good luck.
Apr 17, 2009 | Dryers
Indesit wm 12x
Sounds like the pump is blocked. Lost a sock lately?
Mar 13, 2009 | Indesit WA 115 Front Load Washer
No heat on Indesit IS60V tumble dryer
The heater and stats are located at the rear of the m/c behind a removable panel.
you need a meter to test them, more likely to be a stat problem, but again you must test them for continuity.
Plz leave feed back for my solution.
Thanks.
Dec 14, 2008 | Indesit WA 115 Front Load Washer
Indesit washer-dryer wd125 manual
I've been looking for these instructions and have just stumbled across them . Just inside the door there should be a barcode. On the top right check the model no. mine is WD 12S, despite the model no on the outside being WD125.
If so, look here http://imagebank.indesitcompany.co.uk/brochures_online/pdf/indesit/Laundry/WD12S.pdf
ATB
The Mighty Lev
Apr 23, 2008 | Washing Machines
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
165 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
