Question about Culligan Measuring Tools & Sensors
My head vibrates when we use the shower
My system head vibrates when we use the shower and toilet together.
Help
Thanks
Harry
  • 24 Answers
This problem is probably cause by under secured waterpipes. If you by some metel mounting bracket and inplace them that should work. but before you by them find out the best way to get to the pipes. you might have to cut into a wall or ceiling to do this. or if you have a access panal to your water shut offs that should do the trick too
Posted on Nov 22, 2009
Does shower / tub drain into black water tank
Would depend on the plumbing, but usually yes. Only toilet water doesn't.
If you have access to the black water tank, you can put dye in the shower, and then test it.
Jul 07, 2016 | Home
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
When I flush my macerating toilet the shower floods with the toilet waste. How can this be fixed.
you have a blockage in drain system. also make sure the air vent is ok.
Jan 18, 2012 | Saniflo Home
3yr old saniflo + started making loud vibrating noise and smells also small black particles come out - husband opened top and looks like a mesh thing has disintegrated. Toilet is at end of sink, bath /...
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Leaking shower head
Very few shower heads are made to be rebuilt and any O-ring will always be proprietory (i.e. specific to that brand and part). Rohl has an excellent customer service department. The can tell you if the parts are available and will also tell you to get them. 1-800-777-9762.
Apr 19, 2010 | Rohl Shower Shower Head 1025-8
Size of inlet for shower for a saniplus toilet system?
The inlet pipeworks for a shower to Saniflo would normally be 2" / 52mm polypipe as per the diagram (different saniflo unit type, but they are all the same)
If this helps please leave feedback, if not - let me know and I'll try and help some more!
Jan 25, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
Mar 26, 2009 | Home
Measuring Tools & Sensors Logo
46 people viewed this question
Top Culligan Measuring Tools & Sensors Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Culligan Measuring Tool and Sensor Expert? Answer questions, earn points and help others
