Question about Thomson 30LCDB03B 30 in. HDTV
Ihave had problems switching my thomson 30lcdb03 tv on for about 3/4 months. I have had a completely green screen, balnk screen with sound only, and a white ghosting on the picture. Now the tv will not switch on at all. My tv repair man says it cannot be repaired. What do you think?
  • 834 Answers
Thomsom or RCA tv;s are known for power supply issues
check yours for puffed up can like devices on both main and power board if you find one the value is on the side replace it and you will have fixed it won't hurt to try
Posted on Nov 20, 2009
I have a 10yr old thomson TV 21"some sort of unusual voice is coming out what to do??
I have an old Thomson TV 21FDR more than 10 years old. Recently the Tv screen has a lot of disturbances with the screen full of hirizontal lines and a hissing sound. A well trained technican had replaced the tuner with a new one . But after some 2-3 days the same problem is with the tv. Kindly help me with suggestions.
Aug 22, 2010 | Thomson 21DC320 21" TV
Screen is all Green
New cable box recently? If not, your cable provider has probably pushed a firmware update to your cable box. Green screens are very common with HDMI connection. From your symptom, I am going to take a guess that you are connected via HDMI. If so, switch to Component cables and your problem is solved. It's not the TVs fault... cable boxes seem to be the single largest problem child for HDMI compatibility. I hope this was of some assistance.
Apr 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Thomson dti6300-16 won't record freeview channels....
maybe a defragged hard drive follow this procedure:
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Oct 02, 2009 | Arris DCT2608
Green spots/pixels at top of TV screen
I have a 50" Pioneer PDP-503MXE with the same problem - the fans don't run. It appears to be a problem with the temperature sensor that controls the fan speed. However, the fans can manually be switched to MAX.
To do this, put the display in standby. Press the 'Menu' button and within 3 seconds press the 'Power/Standby' button. The 'Integration Menu' will appear. Select the 'Option' tab on the right. Scroll down (next page) to the 'Fan Control' option. It will most likely be set to 'Auto'. Press 'Set' to change it to 'Max'. Within a few seconds the fans will run.
At Max the fans are a bit noisey but it will cool the unit down.
May 05, 2009 | Pioneer PureVision PDP-503CMX 50 in....
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
Mar 05, 2009 | Arris DCT2608
Thomson DT!6300-16 has stopped working
Usually to fix most odd problems on the Thomson digi box you should do a hard disk format every couple of months, select menu, setup, help,
press green button on remote
this shows advanced menu, press blue button, warning should show,
press green button to proceed
takes about 2mins you lose all recorded programs
If the problem is the box stays at red, and won't switch on,
pull the mains plug wait a few secs then push and hold the the standby
button on the main box (not remote) then insert mains plug, as soon as the
red light flashes release the standby button and very quickly press
menu and OK in that order, don't hang about, it has to be done very quickly
I had to do it several times before I got it right, this loads a preloaded firmware
and the box will come alive again the box will upload new firmware in a couple of hours.
good luck from Ron.........
Dec 04, 2008 | DTK PRM-0031I Motherboard
THOMSON SCENIUM 44RW65US Red light flickers
i have the same problem. i have to switch it off at the mains 5 times b4 it comes on
Feb 08, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Shut-Off Problems with Philips 28ps6515/05
Green Screen with some lines lines are called retrace lines. it is due to maybe dry soldered or no green drive signal. This problem can be fixed by complete soldering in crt board. 1 green video supply absent 2 loose contact in green skt in crt board 3 crt board loose 4 no green drive signal.
Sep 15, 2007 | Philips 32PT6441/37 32" TV
Screen not showing picture
Check and make sure you are on tv not video. Unplug and replug all the game systems or other things you might have plugged in your tv. And if those don't work make sure you are not on input channels (input1, input 2, and do on). If still you are having problems go to the tv menu and and make sure you are on antenna if you have a antenna or cable or satilite if you are on one of those. I hope this helps!
Apr 11, 2006 | Thomson AQUA14 TV
Thomson 30LCDB03B 30 in. HDTV Logo
491 people viewed this question
Top Thomson Televison & Video Experts
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
