Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher paykel empties as it fills (similiar to recent entry)
My eco smart model from 2001 continues to attempt to fill but no water stays in the drum. When downstairs I noted that as it is filling it is also draining. This happens in all cycles EXCEPT permanent press. I was told by a repairmen that it probably was the diverter valve and if not that it was the circuit board. Cost was 150-300 depending on issue. I am handy, and Fisher paykels dont have a lot of hardware. Is it the diverter or as one of the older post stated is it the inlet water valve. Water does go in but drains at same time. Any help would be greatly appreciated. I would like to do the service myself if it is as simple as the diverter or inlet valve. Do you know where to buy parts? I live in Southeaster Wisconsin.
Thanks
brian
  • ccrx Jan 21, 2008
    having same problem with gwl10 fisherpaykel
  • ccrx Jan 21, 2008
    washer fills and drains at same time on all cycles but permapress on my gwl10. i checked drain hose its 3 feet from floor
I had the same problem with my Fisher and Paykel washer. I replaced the diverter valve and it seems to be working fine. (Although I have only run one load so far.) I ordered the part from Fisher and Paykel. It came in 5 days. It was under $25, and it was simple to replace. Just make sure you get all of the water out of the washer first. There is a surprising amount underneath that has the potential to cause big problems if it leaks onto the pump.
Posted on Jan 25, 2008
    President:
  • 1,294 Answers
Check your drain hose behind the machine. This should be approx 3 feet from ground level; then into the wall standpipe. The fix behind should not be air-tight. Your pump pumps the water 'over' this height. This may be silly.....but just check.
& rate if helped pl....................or 'thanks for trying' & your prob will be back here on the net for further solutions by anyone else.
Posted on Jan 12, 2008
Eco intuitive error 40
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Error code 49 f&p aqua smart wl80t65c
49 is a cold water valve fault. test the valve for voltage while filling, it should be recieving 24V. if not, the problem lies with the motor controller.
Aug 30, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
My Fisher Paykel 8kg Intuative Washing Machine doesn't work on the Eco Wash cycle
Your eco Diverter valve has failed. this is a wax solenoid and is a common part to fail, it is located under the machine in the drain hose next to the drain pump.
Check out the below link for a service manual
Link:
Mar 10, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
058 model does not fill up continuously, water in and stops starts and stops does that a few times and stop completely and beeps all lights stays on. Please help. Thanks
I have the same problem, just checked the switch and its all ok. But the machuine also stops and starts when its trying to empty after the last rinse cycle to start the spin cycle. Starts to drain then stops and repeats, it does empty some without stopping but starts to go silling when its nearly empty?
Jan 15, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher paykel eco-smart washer is filling up with water at the same time it is pumping the water out the drain.
My washer is filling up..but not very high and at the same time it is pumping out water into the sink. Will not spin or rinse
Jan 01, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
280 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
