Question about Panasonic WORKiO DP-1520P All-In-One Laser Printer
In different size cannot rotate sort - Panasonic WORKiO DP-1520P All-In-One Laser Printer
  • 100 Answers
Yep!
you can ony perform rotate sort in the following paper sizes:
a4 or letter
Posted on Mar 26, 2010
My 2005 infinity has all of a sudden thrown me 3 different lights. Service engine soon, vdc off, and slip. I recently had a flat and got a used tire put on. The car stalls to start and is now cutting off...
Your tire sensors are sensing different size tires./ Your tires are rotating at different speeds because of the size difference. put the same tires on the front axle if front wheel drive. and the same tires on the rear if rear wheel drive. be sure to match tire pressure.
Aug 03, 2014 | Cars & Trucks
Can i put 235/70r16 tires on when 225/70r15 is original
Not when the wheels are different diameter
You can try tire rack.com or a local tire store
for across reference on tire sizes
If you go from 225 to 235 you have to go to a lower
profile like a 60 or 65
You speedometer,trans & all sorts of issues may
come to haunt you with different tire sizes
Jan 24, 2013 | 1996 Ford Explorer
I Had the tires rotated on my 2008 mazda cx9 at 13,000 miles in our local shop here,then i noticed a humming sound coming from front of vehicle and only when it approaches 50 to 55 mph,could it possibly be...
The noise is most likely caused by the different wear pattern on the tire that came from the rear of the car. The difference in the alignment between the front and rear suspension systems causes the tires to wear accordingly. It will take some time for the tires to wear in to their new environment. The noise should go away gradually. You should also check your tire pressure to make sure you don't have an improperly inflated tire.
Dec 16, 2010 | 2008 Mazda Cx 9
A java code for anagram
import java.io.IOException;
public class AnagramApp {
static int size;
static int count;
static char[] charArray;
public static void main(String[] args) throws IOException {
String input = "Java Source and Support";
size = input.length();
count = 0;
charArray = new char[size];
for (int j = 0; j < size; j++)
charArray[j] = input.charAt(j);
doAnagram(size);
public static void doAnagram(int newSize) {
int limit;
if (newSize == 1) // if too small, return;
return;
// for each position,
for (int i = 0; i < newSize; i++) {
doAnagram(newSize - 1); // anagram remaining
if (newSize == 2) // if innermost,
display();
rotate(newSize); // rotate word
// rotate left all chars from position to end
public static void rotate(int newSize) {
int i;
int position = size - newSize;
// save first letter
char temp = charArray[position];
//shift others left
for (i = position + 1; i < size; i++)
charArray[i - 1] = charArray[i];
//put first on right
charArray[i - 1] = temp;
public static void display() {
System.out.print(++count + " ");
for (int i = 0; i < size; i++)
System.out.print(charArray[i]);
System.out.println();
Nov 22, 2010 | Computers & Internet
Hi,Wondering if all you sunnies aficionados are able to provide me with a size comparison of the Ray ban Wayfarer 2132 medium (901-52mm) and large (901L- 55mm) , preferably being worn? I would like to get...
The size is the width of the lens from the widest part. The larger the frame, the larger the lens. There is a slight difference in size in terms of the frame because the frame has to be able to accommodate the size of the lens, but the difference is not great.
Nov 07, 2010 | Clothing Accessories
Noise in transfer case plus uneven tire size
Sound's like you might have damaged the transfer case due to differant tire size.The differant tire size causes uneven rotation inside the case and it will damage it.Take to tranny shop and have them check out.
Aug 20, 2009 | 1996 Jeep Grand Cherokee
Question on rims on a 1988 IrocZ28. the front rims have a stamp on them indicating 'front' and the back rims 'rear'. the tire size that came on the car when I bought it are P245/50/R16 (96T-mts). Im pretty...
Those wheels are what is referred to as "staggered" meaning different sizes front and rear. If you measure the width of the wheels the rear ones will be wider. I'm not sure what size you are supposed to be using but the rears should be wider. This kind of setup is not designed to be rotated. You could rotate side to side but this won't even your wear out.
Aug 08, 2009 | 1988 Chevrolet Camaro
Auto 4 wd on 2003 trailblazier is not cutting off.
Hi there... The different size is tires could be causing you problem. The other thing is that if you are using your 4x4 with the two different sized tires, you are causing more damage than you think. The reason is that with two different sized tires, your axles are rotating at different speeds. This is ok in 2wd becuse there is no power transfer to the fronts but once you engage the 4wd, now you have power to the fronts and rears and could damage the differentials.
Jan 14, 2009 | 2004 Chevrolet TrailBlazer
Paper getting jammed when rotate sort
To clarify LT and LT-R are both 8 1/2" x 11", most models of Toshiba will ask what size paper are in the drawer when they are open and shut,. if you have LT paper (landscape) in a drawer, but tell the machine it is LT-R (portrait) when it tries to feed it will jam because it "senses" you are missing 2 1/2" of paper. So make sure your settings are correct, in my experience this is 90% of the jamming issues on Toshibas. Rotate sort uses both drawers to interleave the LT & LT-R into "stacks" so they must be opposite directions but corresponding to correct direction (portrait, landscape)
Oct 23, 2008 | Office Equipment & Supplies
Engine rotates,but will not start
there is a kill swith on the escorts its a factory fit thing they put them in the boot or down by your feet hid behind the plastic trim it looks like a black box about the size of a tab box with a red button on the top when u find it push it in and this should sort the prob i had the same prob on my cabby when i lowerd and that is what it was hope this helps
May 28, 2008 | 1993 Ford Escort 4 Door
Panasonic WORKiO DP-1520P All-In-One Laser Printer Logo
59 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
