Question about E-Machines eMachines W2686 PC Desktop
How to finde the right ram and fit it iqon desk top it has 1g i want to fit 2g
  • 25 Answers
Http://www.memoryupgrade.pro/emachines-memory-w-series-w2686.html
This link will give you the specs you need and then you can go and purchase the ram wherever you want to. If the page displays weird when you click on the link just refresh the page and all should be well.
Posted on Dec 02, 2009
Will extra computer memory be used if the maximum is exceeded?
Windows XP can't use over 2.1 GB of RAM for applications though up to 4 GB can be allocated. The extra RAM is used for the system only. It shouldn't hurt to have extra there.
Nov 10, 2013 | E-Machines eMachines Desktop PC
T6524 won't recognize all ram
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Feb 24, 2013 | eMachines T6524 PC Desktop
INSTALLED NEW RAM UPGRADE TO BOOST FROM 1G TO 2G COMPUTER DOES NOT RECOGNIZE NEW RAM STILL SHOWS 1G.
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
Nov 19, 2010 | E-Machines eMachines Desktop PC
Information on what type of memory upgrade device
Standard Memory: 512 MB - (MegaByte)
Approximately 1 million bytes','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>MB
(Removable)
Maximum Memory: 2 GB - (GigaByte)
Approximately 1 billion bytes, or exactly 1 byte x 1,0243. (1,073,741,824) bytes.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>GB
Expansion: 2 Sockets
CPU & ChipSet: AMD Sempron
Bus Architecture: PCI; USB - (Universal Serial Bus)
Standard connection for peripherals such as digital cameras, scanners, printers etc. Allows for quick and easy data transfer. Uses the plug and play facility available with Windows 98 / ME / 2000 XP or Macs.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>USB
Mfgr's System P/N's: N/A
Comments MODULES MUST BE ORDERED AND INSTALLED IN PAIRS for Dual Channel.
KVR400X64C3A/512
KVR400X64C3A/1G
KVR400X64C3AK2/1G
KVR400X64C3AK2/2G
Jul 22, 2010 | E-Machines eMachines Desktop PC
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
1993 mitsibishi eclipse G1 to G2 engine swap
turbo? if you have a 1g GST or GSX, your gonna wanna swap in a early 1g 6-bolt engine.
the optimal configuration using stock 1g/2g parts would be:
  • 6-bolt w/2g pistons. compression: 1g= 7.8:1 2g= 8.5:1
  • 1g head/intake manifold
  • 1g throttlebody
  • 2g throttlebody elbow
  • 2g exhaust manifold
  • 2g o2 housing
  • 1g 14b turbo
Oct 12, 2008 | Mitsubishi Eclipse Cars & Trucks
IBM ThinkPad T40 2GB Max RAM
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Jul 08, 2008 | IBM ThinkPad T40 2373 Notebook
Why MIS P4M900M3 couldn't support 1GB ,2GB RAM when they are together?
You can't use two different size at a time, they must be of same size. If you will use two sims both of 2G then it will work, either you can use both of 1G.
There is no problem no your motherboard niether in SIMs.
Thanks
iqbal
Mar 16, 2008 | Intel Motherboard
Increase RAM
You can increase the RAM only if it's DDR2 up to 2g,
Jan 22, 2008 | Computers & Internet
E-Machines eMachines W2686 PC Desktop Logo
112 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
