Question about Kenmore Washing Machines
Kenmore he3 dryer check lint screen flashes and dryer wont start. Yes checked lint screen
    Brigadier General:
  • 3,513 Answers
Hi
Try unplugging it or turning off the power at the breaker panel. This should reset the controls.
Weather this works or not, make sure that the whole dryer vent is clear. often we find a clog in the flexible line, or where the duct exits the house. also there are situations where the clogged duct caused a lint plug inside the dryer. Assuming you can reset the controls, you can run the dryer for a minute with the hose unhooked to see if you are venting the right amount of air.
OR
It is possible the heating element has gone out or one of the thermal disk has blown its fuse. If you turn the dryer on holding the button that is depressed when the door is closed so that the dryer will run you should be able to see if the heating element is getting hot because it should show as a red glow. If this is not happening then most more than likely the heating element has gone out. Most of the time they are fairly easy to replace.
OR
a simple thing is that When the lights are flashing, it is an error code, which indicates a problem with the door switch. Could be a loose connection there.
Thanks for contacting fixya.com
Posted on Nov 20, 2009
Once I press normal dry and press and hold start machine beeps with time remaining flashing
You either have a bad door switch or thermoresister is bad
dryer should be flashing a code also check your lint screen make sure dryer is not clogged up check vent going out
if thats not problem then its main relay power board
Mar 23, 2015 | Kenmore Elite HE3 Steam 8674 Dryer
He3-false lint screen warning.
try to get in with big vac slim hose to get down in lint area sensor mustr be milted on it down in ther were u take it out to empty
Feb 03, 2008 | Kenmore 82822 Electric Dryer
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
Hello;
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
How to install dryer rack in kenmore HE3 dryer
Open your Kenmore HE3 dryer door. Look for the ledge on the inside rear of the dryer wall.
Insert the rear wire leg of the dryer rack into the drum, resting the wire leg on top of the ledge. The front frame should rest over the dryer lint screen.
Push down on the top of the front frame of the dryer rack to secure it over the dryer lint screen frame. Close the dryer door once you load your items on the rack.
Feb 02, 2013 | Kenmore Dryers
Sears HE3 Dryer - "Check Lint Screen" light is on. I cleaned lint screen and area around screen but light will not extinguish and dryer will not turn on. I unplugged dryer for a time and plugged back in...
I am not familiar with your dryer, but it sounds like a safety mechanism where if your lint screen is not cleaned the dryer will not turn on. That "Check Lint Screen" light for your dryer may be connected to a sensor near the lint screen area. Check that out and see if that is the problem. If there is a sensor it could be faulty,
Apr 28, 2010 | Dryers
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore he3 model 11082822102 the check lint
remove back panal and clean hose to sensor.
Nov 19, 2009 | Kitchen Ranges
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Washing Machines Logo
531 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
