Whether it's through the camera button on the right side or through the main menu, as soon as I enter camera mode, I get sent right out of it. I'm not sure what the problem is, nor do I have any idea what may have caused it. I just tried to take a picture one day, and it wouldn't let me stay in camera mode. I've checked for possible stuck keys, but it doesn't seem to be the case. Any help would be appreciated. Thanks.
Press the Playback button (the right-pointing triangle, just to the right of the MENU button) to enter the Playback mode then press the MENU button to bring up the Playback menu. Copy is the seventh item on this menu.
With the TV on, press the Menu button which will take you to the main menu
Then select the "Setup Menu" and press enter
Select "Game Mode" and press enter
Select "On" and press enter
Then press Exit to leave the main menu
These steps should get you going, however if you have trouble please
tell me the exact model of your Samsung TV and I can give you further
instructions:
a) How to enter Service mode Follow the procedure below to enter Service mode. 1) Turn off the printer. 2) Turn on the printer while holding down the [Paper Source] button and [Online] button. 3) Check that "Canon W8200" is shown on the display, and then release the buttons. 4) Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will be displayed after the sheets are loaded.) 5) Use the [Lower arrow] button to make a selection. Service mode is added to the options in the Main menu. Service mode can be entered even during error status (when Exxxx and Wxxxx are shown on the display) by turning the power off and then using the above key operation. b) How to exit Service mode To exit Service mode, turn off the printer. c) Buttons used in Service mode • Selecting menus and parameters: [Left arrow] button or [right arrow] button • Entering a lower-level menu: [Lower arrow] button • Entering a higher-level menu: [Upper arrow] button • Setting menus and parameters: [Enter] button
Now under service mode select counter, and select printer and W-INK to reset it, and under initialize select W-INK. But also change the waste ink absorber so that you do not get waterfalls of ink from your plotter :-)
Hi, I've scoured the 3 page manual and come up with this.:- There is nothing wrong with your camera. The camera has a built-in power saving feature that turns the camera off after 30 seconds of inactivity (default setting) to conserve battery power. The auto off time setting can be changed in the set up menu. Changing the Auto Off Time Setting: 1. Set the camera to Camera Mode. 2. Press the Menu button to display the main menu. 3. Press until the Setup is highlighted. 4. Press to enter the Setup submenu. 5. In the Setup menu, press to highlight “Auto Off Time”. 6. Press to enter “Auto Off Time”. Press to highlight the time you want. 7. Press the OK button to save your selection. Hope this helps
1. Start and end of simulations
Note: The "PAUSE" key in the descriptions means the "INTERRUPT"
key.
Simulation IN
The Simulation IN mode becomes only available from the Copy mode
screen.
In the simulation mode, printer operation is inhibited. Printer operation
is also inhibited in either of the Aging mode or the Adjustment Copy
mode. The printer selection key is disabled, too.
By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation
main code input screen appears.
* If the interval between any two key operations is more than 5
seconds, the entry into the simulation mode is canceled.
(Ref.)
1 ~ 9: Loading/ sensor checks
10 ~ 19: Resetting troubles
20 ~ 29: Counter/mode setting
30 ~ 39: Sensor activation checks
40 ~ 59: Adjustments
60 ~ 69: Digital readout and printer
Simulation OUT
The simulation can be terminated by pressing the [CA] key.
2. Simulation main code input screen
SIMULATION NO. _
INPUT MAIN NO. AND PRESS PRINT SWITCH
1 If any trouble has occurred when the trouble code is requested,
the 7-segment readout displays the trouble code (main only).
[Note] The trouble code is canceled when the copier enters the
simulation IN mode.
[Note] The 7-segment readout becomes blank when the copier
enters the simulation IN mode.
2 Only the [PRINT] key LED comes on.
[Note] The [PRINT] key LED is usually OFF. It comes on when
the copier waits for the [PRINT] key to be turned ON in the
simulation mode.
3 The main code input area (2 digits) waits for the input of a main
code.
[Numeric Key]: Main code input
[Note] Codes are entered in the ring format.
[PRINT]: Sets entered data.
[C]: Clears entered data.
[CA]: Terminates simulation.
[Others]: Cancels (ignores) entered data.
4 If a simulation has a sub code, it should be executed on the sub
code input screen; a simulation does not have a sub code, it
should be executed on the simulation execution screen.
3. Simulation sub code input screen
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on. to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working.
Hope this helps.
First Press the MENU BUTTON:
Now you will see: Setup>
Use the directional buttons (big round button) on your camera to navigate throught the menus .
RIGHT ARROW PULLS UP > CAMERA 1 MENU and you will have a yellow highlite on the left side.
use the down arrow to select and highlite>SETUP FOLDER #2,
When you have that highlighted push the > RIGHT ARROW to move the HIGHLITE to the next selection.
>USE THE DOWN ARROW and highlite> CLOCK SET > when that is yellow>use the right arrow to get into it and select> OK PRESS ENTER (the little round button inside the arrow buttons.
AND YOU ARE IN THE CLOCK/DATE/TIME SETUP MODE MAKE YOUR CHANGES AND SELECT OK and press the enter button and you are done. Just press the Menu button to exit the menue
