My washing machine works perfect when it is empty till i put clothes in even somthing as small as 2 pillow slips makes it bang violantly the hole drum and its casing bangs about. can u tell me what is wrong with it .
  • 3,600 Answers
You have a broken drum spring go to www.appliancepartspros.com and look up your machine you will be able to look up the part the price and see how to replace it and yo can order there as well.
Posted on Nov 20, 2009
May i wash it? the dog threw up on it
yes its that material on the underside of the cushion thats questionable right? its seems very rippable just looking at it i did it- and when need be still do as i write as a matter of fact a set is in the dryer on the lightest shortest dry cycle i i was looking to see if there were alternate covers i can get off all the seat cushions like i was gingerly peeling a banana evenly - when the cover was finally peeled off it was perfectly inside out, however the back pillows are instigators of mighty stress of strength . the zipper lengths didnt equate to what is inside they must have put the stuffing in first then sewed it together - leaving an opportunity for possibility for someone to open it or get it out or disengage the 2 2 of my stuffing cover casing ripped tryind to get that square peg of the round hole. wait till you try to get those back in also the back pillows are none the same size all vary in an inch or 2 length wise is the concern cause youll be pushing while trying to get that stretch limo in the garage with door closed youll also have to tread lightly with that cloth material thats whats holding not only the stuffing grouped, but that is also what holds and gives the back pillows that shape, saying all hell and going for the stuff that just gets it all back in so you can cross that finish line of a zipper. will look like a sack of potatoes albeit more rounder and fuller than before and upon realization more comfortable and plusher and that nightmare of a material that holds the whole shape of you is the very same material as the other black cloth on the couch inside that is a fluffier version of cotton balls and they dont take any shape in the pillow if that sheath of a stuffing cover is not in tact ..... wash in warm/cold no fabric softeners, dryer sheets or things that specifically boost fragrance. i wash the pillow covers with the pillow covers in case something changed, it wouldnt be mis-moshed and still maintain some form of symmetry if something salvageable happened and it did, the pillows had a new look like a textured suede- the material itself is unchanged and fine but still is just has different umph. while the cushion covers ( dressed back the same the process i was undressing but backwards (like putting a sock on in the style of rolling the socks down on your hands so your thumbs reach the toe area and you out your toes in where your thumbs are holding and pull to unravel ) like that they are without hitch (from inside out to right side out along the way back on the same way because from that initial back pillow debacle was an experience i will never forget. i do wash them if the couch facade gets out of hand my pillows are just comfy and because exact form was lost on the first date their symmetry now lays in the form of the pattern of the material the cushions however they stay stout ironed formed even though as opposed to the cotton balls for pillows the cushions are stuffed with the stunt double of cotton candy because of that it gets boundlessly caught in the zipper and it wont zip i got a tiny gauge allen key and put it through the zippers hole and T' pulled with ease i had to then put my hand on the inside track traveling with my zippering hand to guard further trespass of the zipper in hind sight when my pillows had distinct shape if i had done the cushions first before the pillows i may have had a different experience than that life event of that task with the pillows. I learned real quick with the cushions undressing and dressing them is to work from corner nearest you then move on the too corner nearest that corner and operate in that function its all about the corners with the cushions ( the L shaped cushion when your struggling against the cotton candy invasion, while the zippers legs are 3 inches apart and your pulling to zip them together while working on that curve straddle it sideways and squeeze your thighs together ......the pillows however good luck getting in to even get to one.
Jan 02, 2013 | BOBKONA Manhanttan Reversible Microfiber...
Low Water Level in Roper washing machine
You need to check the pressure switch which is also called the water level switch. There is a small tube attached to it and it may have a blockage or a hole in it. You can find this behind the control panel to the left of the timer.
Nov 14, 2009 | Washing Machines
Everything works fine but it will not spin
Hi, you got water pump problem, some pump have a filter you can remove and clean, or some some small clothing could get into it. or you can open water pump and manually check for foreign object. you can empty machine, by lowering drain hose to floor level, you will need somthing to collect water, then check pump.
Aug 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer works fine till it gets to the spin cycle, makes very loud bang bang bang like it's going to blow up, did find two brass pins under the balance plates in a small cup that it droped down into, lined...
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Feb 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Hotpoint Aquarius WF250 Loud banging when spinning
The hardest amount to balance is a load with just one item.Because you have nothing to counter balance the other side.So,first off,put in a normal load ,make sure your washer is level by using a level to assure it is, other wise if its not all the clothes will group in one spot where its not level ,than when time to spin you have a un balanced load.
May 21, 2008 | Washing Machines
My machine makes pin size holes in thin t-shirts and not other clothes. It has ruined several new shirts-help!
It's a nasty twisty thing, my dear. It happens in just about every machine. The only thing you can do to be absolutely sure is to put those thin t-shirts in a pillow case, Strap it closed with one of those "what's those hand-cuffy things called" things? and pray you don't get small pin-sized holes in your pillow case.
Mar 04, 2008 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
