Question about Canon CLC 5100 Copier
Minolta di 251
Minolta copier di 251service code coo70
thank you
jerry
  • 2 more comments
  • Anonymous Mar 13, 2014
    code sc23-02
    my konicaminota di5510 touch panal not working.... some times its works or sometimes not....and now my copier show s a code sc29-04
  • Anonymous Mar 15, 2014
    how to clear the user code on Minolta Di 2610
  • hhh276 Mar 07, 2017
    You welcome jerry
What you can also do is shut down your copier remove the toner bottle, turn the copier back on. Let it warm up. either put back in the toner bottle or if your replaceing it with a new one put it inside and you should be fine. If not make sure there is no cranking sounds going on cause usally it's your toner hp motor thats bad..
Posted on Oct 29, 2008
  • 589 Answers
That's a toner bottle motor failure code.
Check that the bottle isn't "jammed" into the machine and moves freely.
Posted on Jan 11, 2008
Re DiAlta di 251
What about the Di251?
Jun 03, 2014 | Minolta DiALTA Di183 Copier
Error code sc23.03
Minolta Di 750 error code SC-23-01 i want solutions this code.
Sep 17, 2013 | Konica Minolta Minolta Di 650 Di 551 Di...
Minolta di 251 error code c133a
Electrical disconnect Draws #2 draw #3 draw #4 and Draw #5 all connections for each of those draws is in the rear middle cover. Also remove the job tray that the device where the paper comes out for faxes print etc. leave only draw one connected power off the machine turn back on after ten seconds. if the code is gone have a bad draw (s) if it comes back replace the main board if you can find one. The Di251 is legacy machine Minolta is now Konicaminolta. If the code did not come back your going to start connecting each draw back one at a time. Fig out which one(s) is causing the problem
Feb 06, 2013 | Minolta DiALTA DI2510F All-In-One Laser...
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Dec 08, 2012 | Konica Minolta Office Equipment & Supplies
Di 251 code c0214
Power Supply, High Voltage Power supply or the Master Control Board, machine on a good surge protector if not after getting these part recommended you get one. Did you have a brown out or a black out. or electrical failure, 1st go with the Power Supply since that feed the other two, then the High Voltage then the Master board, all of this is predicated if you can get these boards the Di251 Series is a Legacy Minolta Series now Konica Minolta, good luck try below web site as a start to find parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 13, 2012 | Minolta Di251 All-In-One Printer
Problem on Minolta DIALTA DI 251? my copiers haVE detected problemS, one says code M4 What are the problems?
Touch the Utility, Meter counter, Stop00 stop 01, now in service mode now stop 9 select copy kit counter then select mode 1
M-4 is set up to monitor what ever the tech wants it to be
Jun 08, 2011 | Minolta DiALTA DI2510F All-In-One Laser...
How to reset a minolta Di 251 after replaceing Imanging unit
should when you replace the image unit with a new one, then the new one is not new
Jan 08, 2010 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
MINOLTA DI ALTA 200 Y 251. NEEDS TO KNOW HOW TO MAKE IT SCAN.
well..the scan function is accessible from the main panel, OR the desktop manager. do you have a user manual for this elegant device?
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Minolta Di351 All-In-One Laser Printer
Minolta di 251 srror code coo7o
Jan 11, 2008 | Minolta DiALTA DI2510F All-In-One Laser...
161 people viewed this question
old marine
old marine
