Question about Epson Stylus Photo R220 InkJet Printer
Paper will not pull through and then red light comes on
  • 235 Answers
Try checking if you still have ink, if theres no ink better refill it or purchase a brank new ink cartridge,
Posted on Nov 20, 2009
Paper jam showing red light
did you get a full sheet of paper back out when you removed the jam? If not there is still a small piece of paper in the machine. You will need to get a flashlight and look carefully in the center of the path from where the paper starts (the paper tray) to where it comes out when it is done. if you cannot find any do this: best if you open and close all doors and lids. even the doors behind the printer if there is one. If that does not help try this: Turn off the printer, unplug, count to 10 then plug back in and restart. If the light is still on then light is saying a sensor is seeing a piece of paper or thinks it does. It is possible while you pulled the paper out you pulled a sensor flag out of its holder. By pulling the paper out opposite the paper moves through the machine can cause this. always try and remove a jam with the flow of paper, in other words the same direction the paper travels not backwards. Once fixed can prevent this failure in the future.
Jul 10, 2012 | Xerox Phaser 3117
Om line error red light is on
Try this solution: Check for paper jams when the "Error" LED lights red. Open and close the front cover. The paper may automatically be ejected from the printer. Gently pull any remaining jammed paper straight out. Open the front cover. Pull the toner cartridge out. Pull out any internal paper jams.
Nov 21, 2010 | Samsung ML-2510 Laser Printer
On line error red light come on no printing
check for a paper jam. open it and pull the paper out then reinstall paper. close the from door of the printer and this will reinitiate the printer. the green light should come back on. If this doesn't work take out your cartridge and put it back in. close it up again and it will reinitiate the printer again.
May 28, 2010 | Samsung ML 2010 Laser Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
May 06, 2009 | HP LaserJet 1020 Printer
The paper only feeds part way and then stops. Red light comes on
Following a suggestion on another post, I tilted my printer so it is at a slight angle backwards, higher at the front. So far this has worked.....
Nov 12, 2008 | Samsung ML 2010 Laser Printer
Red light stays on and will not print
there is a second piece of paper stuck in the machine.
open the back flap, look at the diagram, and pull out a piece of hardware
behind this hardware, all crumpled up, not visible, is a jammed piece of paper.
Jul 11, 2008 | Brother HL-5240 Laser Printer
EPSON STYLUS PHOTO R 200
THE ROLLERS THAT PULL THE PAPER THROUGH SEEMS TO BE MESSED UP. WE HAVE TO REPEATEDLY RE-ADJUST THE PAPER, THE RED LIGHT FLASHES, OVER AND OVER AGAIN BEFORE IT FINALLY PULLS THE PAPER IN TO PRINT. ARE THE ROLLERS SHOT? DO WE NEED A NEW PRINTER?
Jun 30, 2008 | Epson Stylus Photo R200 InkJet Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Not printing
The red light, along with the paper light being lit indicates that it is having a problem feeding the paper OR it is set wrong for duplexing. Check your manual on page 3-4 or download a manual at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_5140_5150D_5150DLT_5170DN_5170DNLT_EN_1295.PDF
I can't tell which of the error conditions fits your situation, but this should put you on the correct path to figure it out.
May 22, 2008 | Brother HL 5150D Laser Printer
Epson Stylus Photo R220 InkJet Printer Logo
104 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
