Question about Whirlpool GI5FSAXVY Stainless Steel Bottom Freezer French Door Refrigerator
Remove Faceplate on fridge
How do I remove the faceplate on the outside door for the water/ice dispenser? I am trying to remove it so I can get the annoying plastic film off the fridge that came like that from the factory.
  • bigmd10 Dec 13, 2009
    I figured it out after going back to store and making them take it off the floor model. After removing the screws take a very small flat head screwdriver and pop out the bottom part. To do this put the screwdriver inbetween faceplate and the fridge right above where you removed the screws. There are 3 clips that hold it on, just locate 1 of them and use the small flathead to pop out the bottom and the top comes right off. When puting it back on start at the top and just pop the clips back onto the faceplate.
I am have the very same problem. I removed the dish beneath the water/ice dispenser, and located two small screws. These two screws appear to hold the bottom of the face plate to the door. I removed them. However, the faceplate still did not come loose. I suspect there are more screws or clips toward the top.
Posted on Dec 12, 2009
Door faceplate removal
open the door pull the door seal, you should see some screws that hold the seal in place you wil have to remove all of them around the door,this will free the inside liner and you will have complete acces to the water and ice dispansers from the backdoor
Mar 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I take the ice and water dispenser faceplate off? The shute that allows the ice to come out of the freezer is off the track. I cant figure out how to take the front faceplate off so i can get better...
usually a couple of slots in the bottom of the faceplate. gently insert screwdriver and pry bottom loose. push upward to remove rest of faceplate.
Jan 03, 2010 | Whirlpool Refrigerators
Remove protective film wrap from under water dispenser faceplate
I have this same model and was facing the same issue. I even emailed Whirlpool but that didn't help.
You can remove the faceplate by removing the spill tray and unscrewing the two small screws in the bottom. Be careful not to scratch the finish while removing the screws.
The faceplate is held on by several plastic hooks around all edges. Carefully grip the bottom of the faceplate (I put my thumbs on the inside where the spill tray was and my index finger below the bottom front of the faceplate). Get a good grip by pinching the faceplate and pull down and out to remove the bottom. Then push the faceplate up to unhinge the top.
You can let the faceplate hang by the wires while you remove the plastic. I'd also use a stainless steel cleaner while the faceplate is off to get rid of any fingerprints you may have left behind.
To reinstall, hang the faceplate on the top 3 hooks making sure there is a snug fit. Then pull down on the bottom and push it in. It took me two tries to get it back on.
The plastic is stronger than it looks but you'll still have to go slow and be careful with it. Good luck!
Sep 09, 2009 | Whirlpool Refrigerators
The water dispenser is displaced on my Whirlpool refrigerator ED5RHAX NO00. I am trying to remove the face plate but am afraid to crack it. Any suggestions?
I eventually managed to remove the faceplate, using a screwdriver in the bottom slots of the faceplate and prying it loose, sliding it up to remove it from the slots at the top of the faceplate.
Aug 31, 2009 | Whirlpool GS6NBEXR Side by Side...
Remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Water dispenser leaks of my whirlpool refrigerator gs6shaxk b01
on the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside.
Dec 31, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GI5FSAXVY Stainless Steel  Bottom Freezer French Door Refrigerator Logo
1,090 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
