Question about Hotpoint Washing Machines
Water wont drain from my hotpoint wt5400. i need to locate the filter, is it in the front or the back of the machine
  • Hotpoint Master
  • 3,463 Answers
If there is no filter located at the front of washer then you need to remove lower rear cover of washer.
Remove large black hose on bottom of drum.
TRemove and clean filter inside hose.
Remove hose onto pump, and check for obstruction or blockage here and in the pump.
Please rate my solution.
Thanks.
Posted on Nov 21, 2009
Hi. is the front filter on hotpoint wma10 removeable. The machine is not draining properly after cycle but putting it on spin only cycle twice removes most of the water.
Most hotpoint filters are Located under the drum centre ..you need to remove the big sump hose/ clipe off then the filter is inside here . give it a good clean the water test machine for any leaks before using...Good Luck
Mar 19, 2011 | Washing Machines
The water wont drain out of my hotpoint machine
Remove lower rea panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside the hose.
Oct 21, 2010 | Hotpoint WMA40 Front Load Washer
Wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Feb 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Fit back and test
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
The water is not draining away. Hotpoint WD63
filter is located at the bottom rear of the appliance... if its pump obstruction then to lay the drain hose into a bowl is a means of getting the water out manually.. if its a blockage and water wont drain this way then lay the unit down on its R/H side (not soap dispenser side)....then acces to the filter can be made without flooding the place..best if 2 persons were to do this as the machine can be heavy when full with water and clothes.. best of luck..
Jan 04, 2010 | Hotpoint Aquarius WD63 Front Load...
The water wont drain or spin wf210 hotpoint
Hi I think your problem is that the filter is blocked, filter is located between drum and pump at the rear, clean that out and that should solve the problem.
Mar 08, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint WF340 wont drain
I have the HOTPOINT WF540 with the same problem ....So remove the front panel at the front of the machine and you will see the filter plug unscrew anti clockwise, you may find it difficult to unscrew as the filter may be blocked solid with coins ans long objects but once you have started it off wiggle it back and forth with some force till the objects dislodge you may be scared of breacking it but the worst you can do is snap of the plunger which is attached to the filter plug, behind the filter plug its self which will do no real harm and you can put it back in unattached to the filter plug with no worries when your done
you can also drain of the water out of the drum drum from this point but you will need a very slim try to fit under the front of the washer below the filter plug DO NOT totaly remove the plug if the is washing machine is full of water, just release the plug till water slowly trickles out and drain it a bit at a time or you will flood your floor
Feb 12, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wf325 filter problem, Blocked maybe?
You are correct as to the location of the filter.
Remove rear panel, locate large black hose at right lower side.
Remove securing clip and hose, inside you will see the plastic filter, remove and clean filter, note location of plastic ball.
Refit filter and hose, and securely fasten hose back on.
When you remove hose, watch out for water, as there will be some in the hose.
water test before fitting panel back on.
Plz rate my solution
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Wont drain water
inside hose at back ,take back lower panel off black hose filter inside.
Dec 19, 2008 | Hotpoint WMA48 Front Load Washer
My hotpoint wma56 wont do its fast spin cycle
Have you checked and cleaned the filter on the machine, usually located and the front near the bottom. If so then there is 2 other possibilities, either your water pump at the back of the machine is blocked or faulty, or it's the timer on the machine. A washer won't go into spin mode until it has drained all the water from the machine first. hence the pump has to run. Just remember to drain all the water from the machine before checking your filter otherwise it will end up on your floor.
Sep 22, 2008 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
