Question about Sony Dual Shock 3 Controller for PlayStation 3
My Dual Shock 3 controller won't connect with the system
My Dual Shock 3 controller won't connect with the PS3 system wirelessly. When using the USB cable, it works fine, but as soon as I unplug it, all four LED lights start flashing, indicating an empty battery. However, I've recharged the controller fully several times and it still won't work.
    Problem Solver:
  • 19 Answers
Go into you accesory settings and change the controllers designation,change it to number 1, it will get changed from time to time cuz of drums or guitars being designated as no 1(especially mic's).
Posted on Nov 26, 2009
When I press my PS3 button on controller, all lights flash for 10-20 seconds then shuts off. it doesn't even turn on the system. If I turn on system manually,it comes on for about the same amount of time...
if this is a woireless controller, it means that the controller needs to be charged. If this occurs when you have the controller connected to the PS3, it means either the USB cable you are using is bad or the rechargable battery in the controller is dead.
Jun 15, 2014 | Sony Dual Shock 3 wireless controller For...
Can't connect orb controller to ps3
Plug the dongle in to the USB port, turn on the PS3 and the LED will flash a lot (as if you've pressed the connect button), then press L3 and SELECT together for 3 seconds; it'll then connect. Then press the PS button.
As long as you keep the dongle plugged in, the controller will not disconnect and won't need pairing again.
Jul 27, 2011 | Intec PlayStation 3 Turbo Shock III...
My 1 month old dualshock3 controller goes crazy and does the wrong action. Sometimes it works correctly only if i connect my usb charger halfway in, thats crazy...
You may have to download a system upgrade for your ps3, It should download automatically if your ps3 is on-line, failing this reset controller and fully charge before using, The "usb charger halfway in" i don't know how you would fix this, sorry.
Apr 24, 2011 | Sony Dual Shock 3 Controller for...
Dual shock 3 controller will no longer stay synced to my system. When I turn on the PS3 I can press the Home button and four lights will flash but the control won't connect wirelessly. When I plug in the...
Have you recently tried using the controller for a different system.
If so, you will need to get a safety pin or something similar to press the little 'reset' button on the back of the controller. Once you press this button, connect the controller using the USB cable and you should be ok.
If this doesn't work, your wifi card has gone bad and will need to be replaced.
To check your wifi card, which controls everything wireless, try connecting your PS3 to wi fi. If you can connect then your card is good. If not, then you will need to have it replaced. Good luck.
Jan 20, 2011 | Sony Dual Shock 3 Controller for...
My dual shock 3 is not lighting at all. i tried connecting it on my ps3 and laptop using different usb cables but still when i press the ps button it didn't ligh
This usually happens when the controls have lost most of their power.
Try leaving your controller plugged in (charging)overnight or for like 2 hours. (Controls only charge with the PS3 ON).
Jan 18, 2011 | Sony Dual Shock 3 Controller for...
Im trying to use my dual shock controller on another ps3 it is a sony controller why wont it sync with the unit
for your playsation to pick up a new controller you much first connect both playstation and controller with the USB cable. and let them sync (Just by playing with the charger cable connected for a while will do)
Jan 13, 2011 | Sony Dual Shock 3 Controller for...
Dualshock sixaxis troubleshooting wired and wireless does not work PS3. I try to wired control from another brand not sony and works.How i know if the console is charging the controls?
while the controller is plugged into the system with USB cord try the reset button on the back of the controller (next to the center screw on top).
Jan 03, 2011 | Sony Dual Shock 3 Controller for...
We have two PS3 systems in our house, each with 2 wireless controllers. How do we get the two controllers from the one system to connect to the other system so we can play a game with all four?
Hook them up directly with the usb cable you use to charge them with to the system you want to link them to and press the PS button to turn them on.
Dec 01, 2010 | Sony Dual Shock 3 Controller for...
Need wireless controller with vibration mode
they don't have it. the dual shock 2 has it. but thats a ps2 controller. the dual shock 3 is a six axis controller, sony opted for six axis instead of vibration. if your lucky you may be able to find a setup to use a dual shock 2 setup to use with an wireless adapter for the ps3. good luck with that one though.
Dec 17, 2009 | Sony Playstation 3 (PS3) Console
Dual Shock 3 Doesn't seem to work at all
i have the perfect solution...
step 1- plug usb into controller, make sure the system is off
step 2- press thee reset button on the back of the controller then turn your system on with the systems on-button
step 3- once the system is on, press the ps button.
step 4- remove the usb and then pres ps again
step 5- it workz, gud lukk!
Apr 12, 2009 | Sony Dual Shock 3 Controller for...
Sony Dual Shock 3 Controller for PlayStation 3 Logo
1,735 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
