Question about ASUS P4S800D-X Motherboard
Adding memory. what type o\and how much
Adding memory. what type and how much
  • 235 Answers
This type of motherboards supports up to 4 gb of ram ddr 400, the price just check with the store that has a stock of ddr 400
Posted on Nov 20, 2009
Testimonial: "quick, precise, and just what I wanted. Thank you"
Presario sr1710nx what type memory
Crucial.com has an excellent wizard for locating memory.
Computer memory upgrades for HP Compaq Presario SR1710NX Desktop PC...
Lists memory compatible with your machine.
Memory Type: DDR PC3200, DDR (non-ECC)
Maximum Memory: 4GB
Slots: 4icon_note.gif Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
I have also found that the memory occasionally is not recognized. To fix remove the ram and clean electrical contacts with a clean pencil eraser. (Rub the contacts to clean.) Then replace memory. (My machine failed to boot, cleaning the contacts fixed the problem.
Nov 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
Trying to put new hard drive.when it starts up it beeps 3 times and no picture on the monitor.is the power supply bad? originaly the hard drive crashed and the trying to reinstall it kept coming up error...
3 short beeps is a base 64K RAM failure
Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
  • Information about installing and adding new hardware including memory can be found on document CHADD.
Jan 31, 2010 | Gateway Computers & Internet
I hace a compaq presario 700 . I added 256 memory
remove the memory ... try again ...
there is the possibility your memory was not seated correctly and/or it is not the correct memory.
remove it to get going again ...
256 is a strange number ...
please go to www.4allmemory.com and have them scan your computer. They will make recommendations based on that scan. Compare what you got with their recommendation.
Truth is a journey not a destination
Thanks for using fixya.com
Oct 26, 2009 | HP Compaq Presario 730US Notebook
When printing PDF colour documents data is missing I understand that adding memory may solve this - is this an easy thing to do , and is there a maximum memory I can add
Adding memory won;t help you. You have to set the print preferences to include everything in the document. If you are getting blue blocks with no data in them, uncheck the "Print Highlighted areas".
As for memory, each computer is a little different. Tiger Direct dot com has a memory checker. It will tell you how much and what type memory your system uses.
Oct 02, 2009 | HP DesignJet 500ps InkJet Printer
I have a dell Dimension 8250 and replaced the memory cards with a higher memory. I got a memory error beep code so I replaced the original. I'm still getting the beep code. Any ideas? I was careful...
Please check the following link for complete information on Dimension 8250
http://support.dell.com/support/edocs/systems/dim8250/
Check the technical specification section to see if u bought the correct memory type for this computer to upgrade..if yes then proceed to the adding and replacing parts section to check for the instructions on adding memory.
Jun 27, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Adding memory
You mean they are physically too big?
There are different types of memory, Double check this type your Motherboard takes. Generally oldish Motherboards take SDRAM, Newish ones take DDR type Ram.
Hope this Helps, Please don't forget to rate my solution,
Thanks.
Mar 14, 2009 | Dell Inspiron 1501 Notebook
Memory/Storage
Additional storage can be added to the MobilePro 900 by adding memory cards to either the CF Card slot or the PCMCIA (PC Card) slot. There are several types of memory cards available, including Flash Memory and miniature hard drives, in both the CF and PCMCIA form factor.
Sep 14, 2005 | NEC MobilePro 900 Handheld
ASUS P4S800D-X Motherboard Logo
183 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
