MAKE MY TONEARM STOP SKATING
I AM ORIGINAL OWNER OF JVC COMPONENT SYSTEM PURCHASED IN 1986. PLAYED VINYL LESS AND LESS AS YEARS WENT BY. HAVE REVIVED INTEREST IN PLAYING MY OLD RECORDS. PROBLEM: WHEN THE TONEARM DROPS TO PLAY, IT WANTS TO SLIDE A QUARTER INCH OR SO ACROSS THE RECORD BEFORE IT SETTLES. IS THERE AN ADJUSTMENT I NEED TO ADDRESS? ANY INFORMATION ON FINETUNING MY TRACKING, ETC. WOULD BE APPRECIATED. THANKS FOR HELP, JOHN
  • OLD HIPPIE Jan 11, 2008
    THIS IS THE ONLY ADJUSTMENT I CAND FIND. THERE'S ONE ON EACH SIDE. THANKS, JOHN
    CAN'T FIND A WEIGHT ADJUSTMENT.
  • 36 Answers
It's possible your weight adjustment has been mis-adjusted since you last used your turntable. On the tonearm, there should be a weight adjustment wheel. Turn this all the way towards the needle (IN). Now, adjust it backwards until there is no resistance in the tone arm - this is your zero point, reset the wheel on the weight adjustment knob to read 0. Now, adjust it forward to 3 grams of downward pressure. This is usually the minimum amount of force needed on a record. If it still skates at this setting, adjust it with gradual amounts of greater force until the skating stops.
Posted on Jan 11, 2008
  • Lucus Keppel
    Lucus Keppel Jan 11, 2008
    The knob on the back is the weight of which I am speaking - not the circle, but the counter weight. In addition, it looks like you have an anti-skate mechanism that can be tried if my first suggestion fails.
    It also looks as if your tonearm counterweight does not have the measurements marked onto it. It should still spin in and out, however. Adjust it by rotating the counterweight counter-clockwise, until it is in the complete forward position. This position will apply the maximum amount of pressure to the cartridge.
    There should now be a feeling of weight and resistance when the head of the tonearm (containing the cartridge) is raised and lowered. Begin rotating the counterweight clockwise (away from the pivot point) until the weight and resistance feeling is gone. It should feel like there is no resistance, indicating exactly 0 grams of stylus pressure.
    Now, rotate the counterweight exactly one rotation counter-clockwise - this should be about three grams of pressure. Start with this position, test it with a LP, and gradually increase the pressure until the arm comes down in the correct spot.
    Also ensure that your turntable is in LP (33 rpm) mode vs 45 rpm mode. If it is looking for a 45, the tonearm may not settle until it is beyond the edge of an LP record.
6ya staff
SOURCE:
I have a technic sl 1200 mk2 , my anti skate is
I gather you don't know how to adjust the tonearm. First put the stylus pressure, and antiskating to zero. Balance the tonearm for a free floating position. Ortofon cartridges will list the stylus pressure, generally 1.5 grams. Dial in the correct pressure, and set the antiskating to the same as the stylus pressure. If you require more assistance, or would like to inquire about repairing your Technics, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 09, 2014 | Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Need to know how to adjust tone arm and anti-skate
Get one of those little mini-digital scales that should sell for about $30 or less. Make sure it reads in 0.1 or 0.01 increments. Unplug the turntable (so the platter doesn't spin) and place the scale in the tonearm path. Most tonearm and headshell combos should work well in the 1.0 to 1.5 g range. Weigh the tonearm balancing on the scale about midway through the path (where it would be in the center of the record)
I used a flat plastic credit size card to protect the stylus on the surface. Don't forget to tare the scale to 0. Attempt to calibrate your weight scale adjustment on the tonearm to match the scale while you are at this. Once you have found a setting that works for you, match that marking on the weight scale adjustment on the anti-skate wheel.
You should have a turntable that sounds nice and is also gentle on your records!
Feb 18, 2013 | Audio Players & Recorders
How do you adjust the tone arm on a Denon DP-47F turntable? Thanks Cosmicharlie
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Apr 14, 2011 | Denon DP-47F Turntable
Just got a new Pro-Jet III for christmas - followed instruction manual carefully - it said to set the counterweight to 17,5 for the cartridge it came with, which I did and when I try to put needle to...
It sounds like the counterweight is set to light for the cartridge. Try increasing the weight in small steps till the record plays without skating and sounds good.
Jan 09, 2011 | Project Debut III Record Player red...
Technics 1210 tonearm skates when cueing vinyl backwards
I've seen this on technics turntables before. Try tightening the screw on the arm.
May 20, 2009 | Technics SL-1210 Turntable
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
May 04, 2009 | Audio Players & Recorders
Well on my technics MK2 1210's, the little anti sketch settings and all the others probably arent set to what they are supposed to be, because my needle arm keeps jumping :P could someone tell me what all...
There are two main things that will influence the anti skate settings.
1) The Headshell Weight and Balance
Firstly, check the data sheet for the cartridge and stylus you are using. It should tell you the correct weight setting which will vary from one cartridge and stylus to another. If the stylus is set too light, it can skate across the disc. This can damage the disc and the stylus. The sound will also be thin and it is likely to distort on high frequencies. If the weight is too heavy, it will not jump but will definitely damage the disc.
If you are a serious vinyl user, get yourself a tone arm balance. This is a device that you place on the turntable and you rest the stylus on a plate which is marked in micrograms. You place the stylus exactly at the correct weight marking and then make adjustments to the turntable settings until the tone arm is balanced. It's easier than it sounds!
If you don't have the data sheet for your cartridge and stylus and cannot find it online, use an old disc that you don't mind damaging, set the weight on the light side and gradually increase the weight until it stops skating.
2) Platter Levelling
Secondly, you need to make sure your turntable us on a level surface. If you are a purist, use a spirit level. to do this.
There are other things that can cause skating and jumping, especially if you use the turntable as a DJ. For example, vibration (caused hopefully by dozens rocking to your music). DJs will often increase the headshell weight very slightly to overcome this and I have sometimes placed the turntables on a thick rubber sheet such as carpet underlay to improve shock absorption.
Mar 26, 2008 | Technics SL-1200MK2 Turntable
Skating
More than likely your tonearm was damaged in transit. A common issue, especially if you had it in a flight case and not properly tied down, or tied down too tight. You will need to replace the tonearm. Tonearms for this unit are available HERE. Word of caution, do not attempt to replace the tonearm yourself, as it is rather difficult, and you could cause more damage. You'll need to find a reputable repair center in your area. Contact Panasonic - UK for a service center near you (Panasonic is the parent company of Technics).
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 13, 2008 | Technics SL-1200MK2 Turntable
503 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
