Question about Samsung S850 Digital Camera
Wont show image veiwfinder in seems like batteries are dead
When turning pwer on the the shootingsettings
You get to the viewfinder by putting an eye to it. The Rebel XT works as SLRs have worked for half a century, showing you the image through the viewfinder. Only more recent dSLRs have a Live View capability, allowing you to use them as point&shoot cameras by viewing the image on an LCD.
Apr 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Camera to show date and time
There is probably a small, secondary battery in your camera. It doesn't power the photo taking parts, only the date keeping and so on. Perhaps it is dead. Take it to a camera store and ask about it.
Apr 04, 2010 | Canon PowerShot A590 IS Digital Camera
I have no image in the viewfinder on a canon S2 IS but the lcd display works and it seems to work fine otherwise. What are the likely causes?
There is sometimes a button on digital cameras that turns off the LCD while taking pictures to save battery. Does your camera have a viewfinder? If it does then there might be a button that looks like a little screen or says "disp" or something like that.
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
The view finder does not wotk
Try pulling out the eyepiece, it will reveal a switch that controls the focus, it maybe the problem, good luck
Aug 13, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
My phone wont turn on
YES, It seems that the battery is dead.
May 18, 2008 | Nokia 7373 Cellular Phone
Sony N2 veiwfinder problem!
Can you see Shadow images[ indicating back light failure]
or Nothing at all[ Indication main circuit board or connector problem
If you are still in warranty then send it back to seller.
You could try gently squeezing the case below the screen to see if there is a chance of a re connection.
Also check out Sony support in case there is an issue with that model
Failing that it is a repair job
Prbably nearly as expensive as simply junking it and start over
May 07, 2008 | Sony Cyber-shot DSC-N2 Digital Camera
My laptop wont start
have to buy a replacement screen buy them on ebay cheap notto hard to install
Jan 28, 2008 | HP Pavilion dv6000z Notebook
Fragmented image
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factry defect ccd imager. the company recalled these unit and replaced with a stronger version of ccd imager( they are still doing it). check it out.
Jul 28, 2006 | Fuji FinePix S5000 Digital Camera
The viewfinder is dead
Thats an oldie but still a goodie.. this camcorder was made by Hitachi for RCA and its doubtfull that theres any parts available for it. You are probably gonna have to look around for someone with old camcorders laying around and swap out the veiwfinder . these units are also famous for the belts to go bad in them. if you take this unit to a servicer they probably have a flat rate as I've seen online under camcorder repairs unless you think you can do it your self?? Good Luck PS If I get a good look at the veiwfinder and if theres a plug or is it hard wired I may have one as I got several camcorders around the place i use for opsolete parts.
Apr 22, 2006 | RCA CC4252 Camcorder
Samsung S850 Digital Camera Logo
20 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
