Question about D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
I am trying to setup up a D-Link DES-1016D, 10/100 Fast Ethernet Switch to allow 5 laptops to connect, 1 cat 5 is connected to another switch that will provide these 5 laptops internet how can i do this? I plugged it up eariler and could not ping anything
  • Steve Rand
    Steve Rand May 11, 2010
    Did they get an IP from the router?
  • 358 Answers
The Simplest Way of doing this is this:
You will need just 1 switch and 5 Straight-Through cables.
(This is Provided that your laptop will connect to the internet through another method. e.g (Though a USB Modem or WIFI) ).
Connect the Main laptop to the internet through either a USB Modem or a WIFI.
Next, Connect a straight-through cable to the LAN Port of the laptop, and the other end to one of the ports of the switch.
On the network connections page, right-click on the ethernet adapter, go to TCP/IP, and give the laptop a static IP-Address, e.g 192.168.0.1 and Subnet 255.255.255.0
For the other laptops, connect each one of them to the switch using the straight-through cables, and on their ethernet adapter TCP/IP Properties, give them different IP Adresses, but in the same subnet. e.g
192.168.0.2 and 255.255.255.0 for the 1st one
192.168.0.3 and 255.255.255.0 for the 2nd one
192.168.0.4 and 255.255.255.0 for the 3rd one, ....and so on.
Next, in the default gateway for these other laptops, put the IP-Address of the First laptop that is connected to the internet. i.e 192.168.0.1.
Also repeat the same IP Address of the 1st laptop in the Preferred DNS Server for these other ones.
Next, setup home or office network on all of them,
follow on-screen instructions and when you get to the place where you have to select the type of network setup, Just select :
"This computer connects directly to the internet........" for the 1st laptop,
For the others, select : " This Computer Connect through a residential gateway or other computer on my network.".
Then give them all the same workgroup name, and accept file and printer sharing for all of them.
In case you are using Windows Vista.
The only different things include:
When you get to the TCP/IP Place, select TCP/IPv4 and Not TCP/IPv6.
Also, When you are changing the workgroup, all you need to do is to right-click on My Computer Icon, then Properties then go to Advanced, then Select Computer Name, and change the workgroup from there and restart the computer.
What I have told you is a typical, very easy network setup, and I do hope it helps you out.
Keep me posted about the problem.
Hope it helps you out.
Good luck
Posted on Nov 21, 2009
How to setup my des 1008d in my computer
The DES 1008D is an unmanaged switch. therefore there is nothing to set up. Just plug it in and connect to your computer via a cat 5 cable. Here are the manuals
Link DES 1008D
May 06, 2014 | D-Link DES-1008D 8-Port Ethernet Switch...
Dlink DES-1016D switch will support CAT6 cable or not
Yes. Cat 6 is for 1000Mbps / 1Gbps, and is backwards compatible. It will simply default to port speed on unit.
Nov 19, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Problem with D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch
What HW version is your router?
What FW version is currently loaded?
What ISP Service do you have? Cable or DSL?
What ISP Modem do you have? Stand Alone or built in router?
What ISP Modem make and model do you have?
Ensure DNS IP addresses are being filled in under Setup/Internet/Manual?
Turn off QoS options.
Turn off Advanced DNS Services if you have this option Setup/Internet/Manual.
Turn on DNS Relay under Setup/Networking.
Setup DHCP reserved IP addresses for all devices on the router.
Ensure devices are set to auto obtain an IP address.
Set Firewall settings to Endpoint Independent for TCP and UDP.
What wireless modes are you using?
Try single mode G or mixed G and N?
What security mode are you using? WEP, WPA or WPA2? Preferred is WPA2 and Cipher type to AES only if your device support this.
Feb 18, 2012 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does the D-Link DES 1016D 16x10/100 Mbps Networking Switch accept either of strait-through or crossover cat 5e cable configuration to NICs?
Auto MDI/MDIX Crossover
All ports support auto-negotiating MDI/MDIX detection, which eliminates the need for crossover cables or uplink ports. The DES-1016D is the perfect choice for Plug-&-Play support for 10BASE-T and 100BASE-T networks.
See -->> http://www.d-link.co.za/des-1016d.php for further specs.
Hope this helps.
Feb 08, 2011 | D-Link DES 1016D (DES-1016D) 16x10/100...
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Aug 27, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
Does d link des 1016d provides dynamis addresses to network printers?
DLink DES 1016D is seems to be an Layer 2 unmanaged switch which can not provide IP addresses.
If this switch is connected with a router or a DHCP server then it can pass the IP address to any connected device.
Regards,
Rashish
Aug 06, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
All 16 ports are not working
How are they not working?
Check to make sure it is plugged in. Also, try using a different Ethernet cable if you are using the same one to test all ports. If the problem is you are not getting a connection to the internet or something, make sure the router is plugged into the switch and that you have properly set up your network.
Mar 31, 2010 | D-Link DES 1016D (DES-1016D) 16x10/100...
I need to connect dsl to a router then to 9 pc's
connect the router configure the settings give by the internet provider and configure the NAT then u can attach a switch if required and can access....
Dec 29, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-link des-1016d driver
This is a simple network switch and it doesn't require any drivers. You just connect all the computers & other network devices to it using twisted pair LAN cables and that's it.
Dec 13, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-Link DES-1016D make the network failure
Is this a brand new switch? Or did it come from somewhere else? It might have an IP address assigned to it that is interfering with the rest of your network.
Try plugging in a laptop only to the switch and give the laptop a static IP, see if you can access the configuration of the switch.
Jun 22, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
D-Link DES 1016D (DES-1016D) 16x10/100 Mbps Networking Switch Logo
737 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
