Question about HP Photosmart C5280 InkJet Printer
My c5280 was brilliant for printing onto blank dvds. Now it will print paper but not dvds. Can u help ?
  • 3,600 Answers
Go to www.hp.com and clcik on help and support type in the model number and allow it to check the printer for updates and trouble codes, if after running the software if it still does not work then go to live chat for hp and they will tell you what to do next, you must register it first before you get the free support. If it is under warrenty they will also fix it for free or replace it, so I suggest you do this as it will save you money, even thought I won't get rated for helping you.
Posted on Nov 20, 2009
I have an HPPhotosmart C5280. I want to print on an evelope 8.2 x 5.5 for a wedding invitation. The printer tells me paper mismatch every time I try it. I set it up every time on the computer, it prints...
The easiest way to print an envelope is to use Microsoft Word. If you have the software installed, go to start and then create new office document and click blank document. When the document opens, click on help and type in envelope. This will give you instructions on how to create an envelope and save a copy to your document. When you save a copy to your document, it gives you a picture of an envelope which helps to create it. Then click on file, and slide down the print and click ok. Creating the envelope through Word helps to change the printers paper settings. Word will send a signal to the printer to tell it what type of paper and size of envelope you are creating.
Hope this helps?
Jul 18, 2011 | HP Photosmart C5280 Printer
I am trying to print onto pre-printed forms which have a dark blue band at the top. My printer isn't recognising that the band is there so is starting to print too far down the page. Help please!
This type of problem can usually be resolved simply by adjusting the margins from within your word processing program. Depending on which word processor you are using you can go into the page setup and make these changes. For Microsoft Word go to the "File" tab at the top then to page setup. The first tab that comes up will allow you to change the margins on the page. If the print is too far down try reducing the top margin from one inch to 0.5. If that is not enough reduce it some more. Print test pages on regular paper, then hold them up to the light against the paper with the pre-printed band to see how the print lines up. That way you don't waste the expensive paper!
May 20, 2010 | HP Photosmart C5280 Printer
How do I get my C5280 Photosmart to accept 230 gsm card without jamming and then print without smudging? Am I using wrong settings?
If you printer support that specification of paper it will print on it. You have to select appropriate paper type from printer settings.
Nov 12, 2009 | HP Photosmart C5280 Printer
I can't print a letter from my microsof office word program. the printer works but when i try to print t6his letter i doesn't Hp photosmart c5280 all in one printer scaner copier , ineed and up date...
Check if the correct paper size is selected according to the letter size that you are trying to print,select custom size and give the specifications of the paper manually.
Open Solution center software on your PC, click settings>Printer settings, in the feature tab you have an option named Paper type, select plain paper and then click ok and close window and Solution center and try to print.
Sep 27, 2009 | HP Photosmart C5280 InkJet Printer
Printing Direct to CD using Roxio EMC10 and HP All in One C5280
Solved by trial and error.
I went through every type of paper and printer combination listed in the Printer Preferences and eventually found a system compatible with Roxio EMC 10.
This by setting "Commercial Paper" and Neato 3-Disc Paper.
Whilst this is probably the incorrect way to do it, it has solved the problem and I can now print directly onto CD via my HP C5280 All in One Printer.
Tip. If you set Print preview before printing you can determine what the finished article will look like without having to wast numerous Discs trying.
Aug 28, 2009 | Roxio Easy CD & DVD Creator 6...
Continuous PAper jam error-message!!!
Sounds like a small piece of the jammed paper is stuck inside on a paper path switch OR in pulling out the jam you've dislocated a switch actuator so it is not working correctly. Careful checking of the paper path components should find it. Probably a slot in one of the guides is hiding it.
Jul 22, 2009 | HP Photosmart C5280 Printer
My printer c5280 keeps saying please reinsert or lower photo tray
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
I cant print business cards on my hp c5280
Verify no pieces of the card paper are missing and try printing on plain paper to make sure. Then try new card paper and make sure none of the perforations are separated.
Dec 29, 2008 | HP Photosmart C5280 InkJet Printer
HP Photosmart C5280 InkJet Printer Logo
Seeker5211
Seeker5211
